How your Headlight Motors Work., A description with pictures. |
ClayPerrine |
Nov 18 2004, 09:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
NOTE: DUE TO MY NOT LOOKING AT THE WIRING DIAGRAM BEFORE POSTING THIS, I HAVE EDITED IT TO REFLECT REALITY!! (IMG:style_emoticons/default/headbang.gif)
I noticed that there is a lot of questions out there relating to how the headlight motors work. So I put this together to see if I can clear it up. The headlight motor circuit functions like a 3 way light switch in your house. You all have seen them. The one you can turn on at the bottom of the stairs and turn off at the top. Well, when you turn on the headlights in a 914, you turn on the headlight motor. It's rotation turns off the headlight motor when the lights are up, using a set of wiper contacts in the motor. In the first diagram below, I outline the headlight circuit with the lights in the down position. Attached thumbnail(s) |
iankarr |
Oct 2 2021, 12:24 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
This may help…fwiw…I ended up wiring mine backwards…down was up and vice versa (IMG:style_emoticons/default/smile.gif)
https://youtu.be/lx5tKgLG-_k |
Lo-Fi Version | Time is now: 8th June 2024 - 10:20 AM |
