74 914 main wire harness modification, for running a 3.0-6 |
Luke M |
Oct 5 2021, 09:00 AM
Senior Member Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I have my brothers main wire harness laid out here on a table. The rear light portion needs some TLC. While I'm at it wanted to delete the under the seat relay. I know just jump the yellow wire and go. I want to clean up that whole mess of wires if possible. My question is what can be deleted and what can't? I plan on adding a few wires for the 3.0 press/temp gauge and maybe a few other spares from the engine up to the gauge cluster.
Maybe Jeff B will chime in here.... @JeffBowlsby Attached image(s) |
JeffBowlsby |
Oct 5 2021, 09:26 AM
914 Wiring Harnesses Group: Members Posts: 8,548 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
My advice would be to don't bother with the deletions. Study the schematic for the circuits you want to delete and you will see that there is alot that is interconnected, which will then require additional repairs. And for what benefit...saving a couple pounds of wire? Also, whatever you renegineer you wil need an EE to figure things out going forward if ther are problems becasue the harness will have no accurate schematic.
Lo-Fi Version | Time is now: 15th June 2024 - 07:56 PM |
