Advice on 5.5” Race clutch |
BlueRidge914 |
Oct 7 2021, 03:57 PM
Newbie Group: Members Posts: 8 Joined: 18-January 21 From: Ontario, Canada Member No.: 25,093 Region Association: None |
I vintage race a 2.0L six single plug narrow body 914, and for years used a Patrick Motorsport “901” style flywheel and Centerforce 215mm clutch package. I would like to go to their 5.5” clutch and ultralight flywheel, and I understand all the advantages, but I don’t know if that’s offset by lurching around the paddock and in and out of my trailer, and shorter clutch life. Will I forget about that on the track?
Thanks for the advice, Gavin |
BlueRidge914 |
Oct 14 2021, 09:35 AM
With slightly more modest power output than the example above , I should be good to go with 5.5” single.
To the gearbox I years ago added the PMS intermediate plate, side cover, and mainshaft bearing retainer, Tangerine’s shift linkage and console, and J West’s shifter. This after learning the expensive way that eventually the mainshaft starts to dance in the stock intermediate plate and then it all seizes up mid race. More durable now, but how I still envy friends who can shift fast. Don’t know what else can be done! Gavin |
stownsen914 |
Oct 16 2021, 08:22 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
With slightly more modest power output than the example above , I should be good to go with 5.5” single. If you use a Tilton clutch, I recall there are different clutch spring options, the heaviest of which gives something like 250 ft-lbs slip threshold. Sounds like plenty for a 2.0. One thing to keep in mind is that these tiny clutches wear quickly. I recall asking Tilton about this once, and was told that even for lower hp applications like formula V or maybe it was formula Ford, that a single plate 5.5" wears pretty quickly and doesn't hold up for long. Might be worth asking. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:17 AM |
