| thompson-mfr |
Dec 17 2013, 06:14 PM
Thompson, Ryan ![]() ![]() Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
What color is the driving light switch supposed to be for 1974? I have a green one in the car, but in a parts bin I noticed a yellow one.
| Stephen Paul |
Oct 19 2021, 04:17 AM
Newbie ![]() Group: Members Posts: 1 Joined: 19-October 21 From: UK Member No.: 26,002 Region Association: None |
Responding to the questions about green and amber fog light symbol discs on this and other 914 forums: the discs and the switches used on the 914 were sourced from the VW type 4. The two position (on/off) switch made by HELLA the metal body of which is replicated by the HELLA on their range of accessory switches.
It was listed for use with front fog lights, rear fog lights and heated rear window 411 959 621 (switch body) 111 941 515D (escutcheon) 411 953 245A (switch knob) 411 941 543C (green symbol disc - hrw) 411 941 543L (green symbol disc - fog lights) The earliest fog light symbol discs were translucent dark green with two different symbols, later replaced by the opaque bright green disc again in two symbol versions These were diagrammatic representations of the lamp body plus horizontal bars and vertical line representing the fog and limited distance which was for the front lights. The second - for the rear lamp - had a vertical bar behind the representation of the lamp body. The later amber disc seems to have been produced with two different symbols. The translucent dark green discs dated from 1968/9 onwards (Germany having type approved rear fog lamps from 1966 onwards) The bright green opaque discs date from the early 1970s and replaced by the amber in the mid-seventies. A top tip in reducing the distraction of the illuminated disc at night is to replicate an insert VW used on some 411 hrw switches by cutting a circle of scale modellers black plastic card to the diameter of the outer edge of the symbol disc lip and punching a hole in its centre. The black disc should be placed behind the coloured symbol disc and then both inserted back into the rubber knob. Then when illuminated just the switch bulb just illuminates a coloured area the size of the punched hole. In addition to the single position switches found on 914s sourced from the VW type 4 (411/412) model range Volkswagen made a two position switch fitted to the VW type 1 that is compatible with the 914 dashboard for all countries where both front and rear foglight are legal. VW type. three position (on1/on2/off) switch for front (1) and front and rear (2) fog lights comprising of 113 941 541 (switch body) 111 941 515D (escutcheon) 111 941 541F (switch knob - Beetle unpadded dash’ 8/68>) 113 941 541B (switch knob - Beetle padded dash’ 8/68>) and 111 941 543 G (green symbol disc - fog lights) or 111 941 543 H (orange symbol disc - fog lights) https://www.facebook.com/stephenpaulhardyautomotivehistorian [size=2][size=3] Attached thumbnail(s) |
thompson-mfr Yellow or Green Driving Light Switch ? Dec 17 2013, 06:14 PM
boxsterfan On my 1974 2.0L it is yellow. Top picture is a 914... Dec 17 2013, 06:24 PM
thompson-mfr
On my 1974 2.0L it is yellow. Top picture is a 91... Dec 17 2013, 06:27 PM
eric9144 Should be yellow, green is earlier than 74... Dec 17 2013, 06:25 PM
toolguy IIRC, Yellow is for fogs lights. . the button has... Dec 17 2013, 06:57 PM
Pursang The button cover on that switch is yellow in my 19... Dec 17 2013, 07:42 PM
SirAndy driving light switch
Not to be picking nits here, ... Dec 17 2013, 07:43 PM
thompson-mfr
Not to be picking nits here,... Dec 18 2013, 12:36 AM
johannes
What is the difference between fog and driving li... Dec 18 2013, 06:06 AM
SirAndy What is the difference between fog and driving lig... Dec 18 2013, 12:46 PM
Highland My light switch is black with a door jam sticker d... Dec 18 2013, 09:30 AM
eric9144
Not to be picking nits here,... Dec 18 2013, 10:34 AM
SirAndy Not true--true in the US, but not european deliver... Dec 18 2013, 12:43 PM
sarivers2001
Not true--true in the US, but not european delive... Aug 21 2023, 02:21 PM
Question, re: this old thread. Is it correct to ... Aug 23 2023, 07:48 PM
Hawk That is one beautifully done car! Love the hoo... Dec 18 2013, 12:12 PM
OU8AVW So on my 1971 4 I should have a green switch for m... Dec 18 2013, 12:53 PM
SirAndy I am also adding a set of additional driving light... Dec 18 2013, 01:00 PM
eric9144
True to every stock 914. Fog lights, never ever ... Dec 18 2013, 06:04 PM
Shivers @Stephen Paul
That is quite a first post. :) :... Oct 19 2021, 05:04 AM
rgalla9146 ....Goodness gracious Oct 19 2021, 05:24 AM
StarBear
:agree:
My original 74 1... Aug 21 2023, 05:56 PM
Cal This is great info. I’m is the middle of instal... Oct 19 2021, 06:05 AM
Ansbacher I have a '74 2.0 therefore my car came with a ... Oct 19 2021, 11:12 AM
douglastic I love how "green or yellow?" results in... Oct 19 2021, 11:34 AM
Puebloswatcop To make it simple, Yours is a '74. Headlight ... Oct 19 2021, 07:12 PM
Cairo94507 @Ansbacher - For additional visibility, get a set... Oct 20 2021, 06:46 AM
Big Len More than I ever wanted to know about specific fog... Oct 20 2021, 02:01 PM
eric9144
My 74 014 2.0L has the lights inside the bumper, ... Aug 21 2023, 03:13 PM
sarivers2001
My 74 014 2.0L has the lights inside the bumper,... Aug 23 2023, 12:42 PM
Front yard mechanic Ai bot Aug 21 2023, 06:48 PM
eric9144 @sarivers2001 those are US spec fogs with the cor... Aug 23 2023, 01:17 PM
sarivers2001
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 23 2023, 07:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 06:38 AM |
