Exhaust materials question. |
mb911 |
Oct 26 2021, 01:23 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am sure by now everyone understands by now the dire shortage on almost everything right now. Stainless is no exception. I have enough material to make 50 more mufflers and then that's it. I can't afford to sit on 2-3 times the material costs to make the same qty of mufflers moving forward. I have long contemplated making steel versions of my mufflers and headers for both the 4cyl and 6cyl cars.
it is a way to keep everything affordable and continue the awesome design. It doesn't mean I would never make Stainless products any further but would mean that there could be a cheaper option. So the question is would it be something folks would buy? I am not sure how many 1000 dollars would sell out of Stainless but I think steel for under 425ish would? Thoughts? |
Van B |
Oct 26 2021, 04:36 PM
Senior Member Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
So, this is fortuitous timing. I had in mind to PM you about an exhaust setup for my 74 1.8.
One of the things I was going to ask was whether or not you had considered working with jet hot to ceramic coat your exhaust. I did a bit of a custom set up on my 911 and even though it was stainless, I ceramic coated everything but the exhaust tips. The reduction in heat is significant. And I can tell you through years of using jet hot ceramic on my race bike, it holds up real well for a very long time. High heat ares like the collector will lose a bit of the luster, but the coating will hold up just fine. The best part is, if you are looking to make some exhaust out of mild steel, this can negate the corrosion issue and still deliver a reduced cost to the customer. I be happy to be at the top of your list for a system such as this. -Van Attached image(s) |
mb911 |
Oct 26 2021, 05:09 PM
So, this is fortuitous timing. I had in mind to PM you about an exhaust setup for my 74 1.8. One of the things I was going to ask was whether or not you had considered working with jet hot to ceramic coat your exhaust. I did a bit of a custom set up on my 911 and even though it was stainless, I ceramic coated everything but the exhaust tips. The reduction in heat is significant. And I can tell you through years of using jet hot ceramic on my race bike, it holds up real well for a very long time. High heat ares like the collector will lose a bit of the luster, but the coating will hold up just fine. The best part is, if you are looking to make some exhaust out of mild steel, this can negate the corrosion issue and still deliver a reduced cost to the customer. I be happy to be at the top of your list for a system such as this. -Van Van I can make you what you want but at some point they will be stupid expensive unless stainless inventory starts to explode. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:13 AM |
