> The Mega/Microsquirt Mega Thread, There's enough of us, time to share info
GregAmy
post Nov 6 2021, 09:17 AM
Have we decided on which is our official Mega/MicroSquirt thread yet? If so then merge this into it.
I recently took the Microsquirt 914 on a 5-hour each way journey from Connecticut to New Jersey Motorsports Park. I was a bit hesitant to substitute my comfy radio-A/C-and-DSG-equipped GTI for a 45-yr-old ride through the wilds (and traffic) of NYC, but the weather was forecast to be a nice Fall day so I went for it.
Loved it. Car ran flawlessly and the engine was a smooooooooooth as I've ever experienced it. No stumbles, no faults, ran cool on CHT and oil, just an absolute pleasure. 27.5 mpg average on 89 pump gas.
But of course, with no radio (by choice) I had a lot of time to think about my tuning as I was tootling down the parkways and interstates, watching the Android tablet display of engine parameters...it runs good, and it sounds good, and it feels good, but...is it actually good?
One of the biggest issues I faced/am facing with tuning is not the mechanics of the process; I quickly figured out how to use TunerStudio and Megalog, and I'm logging to either laptop or an Android tablet (ShadowTuner) via Bluetooth. And the VE Analyze function of Megalog makes it quite easy to review the AFR outputs in the logs and make changes to meet my AFR goals.
No, that's the easy part. The hard part is knowing where our engines want to be, for example in terms of AFR and ignition timing.
"Take it to the dyno!" you'll say. And you'd absolutely be right. But there's two problems with that.
First, dyno time ain't cheap if you want to do it right. It's not just a matter of showing up and tuning the VE tables to meet the AFR goals (and I can do that on the street). No, to do it right you need to spend an afternoon, or even a day, with a skilled tuner who can run the engine through a series of tests and tickle the edges safely to discover things.
The second factor relates directly to the first: finding a skilled tuner that not only understands the concepts of dyno tuning but also understands the needs and desires of a 75-year-old air-cooled engine design. Sure, the basics are the same as other engines, but I suggest the edges are much much fuzzier.
If I had someone with that talent in my area I'd absolutely leverage them. But I don't. I have some local guys that are good with their dynos but they're Honda guys, or Chevy guys; When I bring my 914 to them (and I have) they're glad to take my couple hours' money but other than tuning to my settings they're not really qualified to tickle (and if they're smart, they're not comfortable trying to tickle the unknown edges on a customer's car).
So any dyno work I've done was to my AFR and ignition settings. And I really don't know what I'm doing either.
I don't know what air-cooled dyno tuning experience there may be on this board, but I'd love to begin sharing some info on where we're going with these Micro/Mega installations. Where do these engines want to be? How much can (or should) we push them? What symptom(s) are we looking for to decide if we need more or less of anything? What's the sweet - and safe - spots?
I'm atttaching my AFR target and ignition tables, let me know what you think. Am I in the ballpark?
I'm not asking you for any secrets. I'm just looking for some feedback to understand if I'm setting myself up for problems in the future. This is not my race car, I'm not looking for that nth hp advance; this is my street car, one that gets driven only 3000 miles a year (if I'm lucky, especially lately). I want to enjoy it and not worry about it. And maybe I'll learn something in the process.
And...discuss! - GA
bbrock
post Nov 6 2021, 08:05 PM
Thanks for starting this thread! It's almost like you read my mind. As some of you know, I'm planning to megasquirt over the winter and think I have a pretty good plan but am in a bit of a holding pattern to finish up a few house projects and also for Mario to reopen his online store so I can buy some sensors. In the meantime, I've been doing the most dangerous thing which is watching youtube vids about tuning and reading this book by the DIYAutotune folks.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images-na.ssl-images-amazon.com-20845-1636250753.1.jpg)
I've come out with the same thoughts as Greg that I don't see a dyno being an option. I have only found one car dyno in the area (there are a few motorcycle dynos) and this is Montana so you can probably guess what kind of cars (hint - trucks) they are versed at tuning. Even the area Euro car specialist mechanic has stopped working on aircooled cars even though they are Porsche guys and one of them has a 914. Also, while that book outlines what seems like a pretty safe procedure for tickling the edges with a dyno, it's all geared toward water cooled engines so not very helpful.
Also, I've read through this thread about AFR several times learning about what is safe for an air cooled Type 4. http://www.914world.com/bbs2/index.php?showtopic=304320. In particular, I'll be taking @Mark Henry 's advice to stay on the fat side to keep CHT down.
To that end, I thought I'd start with an ignition table pretty much like Rob's which looks to be close to a stock curve just to be safe. I still have a lot to learn about when it is safe to run more advance, and what you gain so am enjoying the discussion on that. I was also a bit surprised to see areas going to stoich and even leaner on both of your tables - again, thinking about CHT and being a total ignoramous on the subject myself.
I mentioned this on my megasquirt thread but it seems like a closed loop fattening the AFR or dialing back advance when CHT starts to climb beyone spec would be ideal, but the only out of the box solution I've found is using alternate AFR and Ignition tables triggered by CHT as Greg mentioned. A loop seems like it would be a good way to tickle the edge from the efficiency side at least by building finding the edge into the algorithm. I am not shy of diving in and writing some custom code, but not when a bug could cost me my engine.
As usual, I have only questions and no answers but am bookmarking this thread as it is surely going to be a great resource as I move through my project. Oh wait, I do have one bit of advice, Hey, Greg, you should take 3 out of row 2 column 11. (IMG:style_emoticons/default/lol-2.gif)
GregAmy   The Mega/Microsquirt Mega Thread   Nov 6 2021, 09:17 AM
Montreal914   :popcorn: :popcorn: :popcorn: :D   Nov 6 2021, 10:12 AM
BeatNavy   Good stuff, Greg, thanks for posting. I've go...   Nov 6 2021, 11:28 AM
Montreal914   Nowhere near your level of expertise/experience bu...   Nov 6 2021, 11:40 AM
GregAmy   :beer2: ...You have a lot more advance than I do....   Nov 6 2021, 11:56 AM
falcor75   A good idea is to include the specs of the engine ...   Nov 6 2021, 01:59 PM
BeatNavy   A good idea is to include the specs of the engine...   Nov 6 2021, 02:14 PM
GregAmy   A good idea is to include the specs of the engine...   Nov 6 2021, 03:29 PM
bkrantz   Thanks for setting up this thread. I am several w...   Nov 6 2021, 08:05 PM
bbrock   Thanks for starting this thread! It's alm...   Nov 6 2021, 08:05 PM
BeatNavy   To that end, I thought I'd start with an igni...   Nov 7 2021, 06:23 AM
JamesM   I must admit I'm not 100% sure of the relatio...   Nov 7 2021, 11:19 PM
BeatNavy   So if you are talking about the setting I think y...   Nov 8 2021, 06:43 AM
JamesM   That equation makes perfect sense. I had to look...   Nov 9 2021, 12:53 AM
GregAmy   I don't understand those paragraphs from Tunde...   Nov 7 2021, 06:39 AM
BeatNavy   I don't understand those paragraphs from Tund...   Nov 7 2021, 07:15 AM
GregAmy   Try the overrun cut; here's mine. Should be da...   Nov 7 2021, 07:43 AM
bbrock   Thanks for posting that AFR table with circles Rob...   Nov 7 2021, 10:25 AM
bbrock   And Greg, can Shadow Tuner log mpg? I read about ...   Nov 7 2021, 10:28 AM
BeatNavy   And Greg, can Shadow Tuner log mpg? I read about...   Nov 7 2021, 10:58 AM
JamesM   SOOOO much to comment on here, both general inform...   Nov 7 2021, 12:19 PM
BeatNavy   SOOOO much to comment on here, both general infor...   Nov 7 2021, 01:43 PM
JamesM   SOOOO much to comment on here, both general info...   Nov 7 2021, 10:38 PM
JamesM   Loved it. Car ran flawlessly and the engine was a...   Nov 8 2021, 12:26 AM
GregAmy   In some cases it may be a bit subjective, I guess ...   Nov 8 2021, 07:40 AM
falcor75   I dont run MS on my car but I figured I could post...   Nov 8 2021, 11:01 AM
JamesM   I dont run MS on my car but I figured I could pos...   Nov 8 2021, 01:23 PM
falcor75   I dont run MS on my car but I figured I could po...   Nov 8 2021, 01:50 PM
GregAmy   I dont know about learning anything, but I can tel...   Nov 8 2021, 01:54 PM
falcor75   I dont know about learning anything, but I can te...   Nov 8 2021, 02:03 PM
JamesM   I dont know about learning anything, but I can te...   Nov 8 2021, 03:27 PM
GregAmy   IF (and this is a big if because a lot of people ...   Nov 8 2021, 04:37 PM
JamesM   Lol well I certainly done did it wrong, with many...   Nov 8 2021, 10:10 PM
JamesM   Still working on this one, few things left to dial...   Nov 8 2021, 10:28 PM
JamesM   This probably also worth noting as i know we have ...   Nov 8 2021, 10:39 PM
JamesM   Anyone want more math exercises or for me to expla...   Nov 8 2021, 10:54 PM
bbrock   I'm learning :Qarl: In my noodling around tr...   Nov 8 2021, 09:11 PM
- Lo-Fi Version Time is now: 15th July 2025 - 09:14 AM
