Floor pan repair, How would you approach this? |
vintage914racer |
Nov 6 2021, 10:08 PM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Looming winter in MN means it's time to button the cars up in the garage and dive into winter projects. I need to upgrade the seat on my race car, which kicks off a slippery slope of activities. My seat location has always been compromised (a hair too far from the wheel) due to the floor pan crossbar being in the way. So, in preparation for a new seat, I decided to remove the crossbar.
Naturally digging in I was reminded how bent, beat up and hole-y my floor pan is. So...I want to repair the gnarly, albeit not too rusty except where the crossbar was, pan while I'm in there. If you can tell in the pictures, the LR and RR corners of the passenger pan are mangled, either from horribly wrong jack placement, someone taking a sledge to fit a race seat in (not me, I promise) or some combination thereof. Anyway, I'm trying to determine the best way to do it. Given the rearmost corners are so mangled, I don't see myself patching into those spots, as it would take too much metal shaping. In other words, replacing the full width (long to center console) seems to make more sense. I had so much fun drilling the crossbar spot welds that I'm not too keen on using a full-width patch the full length, however, if I don't have to. Rather, my thinking is that I cut an inch or so in from either side (long on left, console on right) up to the mangled section where I'll go full width and drill out the spot welds from below. Hopefully, the highlighted image makes more sense. Is my logic flawed? Is there a better way to tackle it? I definitely don't want to half ass it. I'm certainly not an expert in this space, although I did carefully observe the expert work @rick 918-2 did repairing my six streetcar (here for reference). |
vintage914racer |
Nov 7 2021, 08:30 AM
I had to do something similar. Wasn’t too hard. Used a sawzall to cut the bad part of the pan out and then just welded in the new. Before: After: I think I saw a post of your repair when I was searching the forums. Given the way the rear corners of my pan are mangled out of shape, I don’t think I can do as straightforward of a cut as yours. Ideally I’d trim right ahead of the upward stamping bulge in the right rear like you did, but in my car that’s actually a downward bulge in its current state. Hence, my thinking that I “should” remove spotwelds and go back to the firewall to do it right without having to do a lot of metal shaping the recreate where the new bulge meets the old, non existent one. |
SirAndy |
Nov 7 2021, 09:52 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Given the way the rear corners of my pan are mangled out of shape, I don’t think I can do as straightforward of a cut as yours. The pans from RD have all the corner pieces. You can literally drill out the spot-welds for the pan itself from underneath and replace the whole rear part in one go. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif) https://www.restoration-design.com/store/product/PP345 (IMG:http://www.914world.com/bbs2/uploads_offsite/www.restoration-design.com-179-1636300352.1.jpg) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:47 AM |
