GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,510 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Have we decided on which is our official Mega/MicroSquirt thread yet? If so then merge this into it.
I recently took the Microsquirt 914 on a 5-hour each way journey from Connecticut to New Jersey Motorsports Park. I was a bit hesitant to substitute my comfy radio-A/C-and-DSG-equipped GTI for a 45-yr-old ride through the wilds (and traffic) of NYC, but the weather was forecast to be a nice Fall day so I went for it. Loved it. Car ran flawlessly and the engine was a smooooooooooth as I've ever experienced it. No stumbles, no faults, ran cool on CHT and oil, just an absolute pleasure. 27.5 mpg average on 89 pump gas. But of course, with no radio (by choice) I had a lot of time to think about my tuning as I was tootling down the parkways and interstates, watching the Android tablet display of engine parameters...it runs good, and it sounds good, and it feels good, but...is it actually good? One of the biggest issues I faced/am facing with tuning is not the mechanics of the process; I quickly figured out how to use TunerStudio and Megalog, and I'm logging to either laptop or an Android tablet (ShadowTuner) via Bluetooth. And the VE Analyze function of Megalog makes it quite easy to review the AFR outputs in the logs and make changes to meet my AFR goals. No, that's the easy part. The hard part is knowing where our engines want to be, for example in terms of AFR and ignition timing. "Take it to the dyno!" you'll say. And you'd absolutely be right. But there's two problems with that. First, dyno time ain't cheap if you want to do it right. It's not just a matter of showing up and tuning the VE tables to meet the AFR goals (and I can do that on the street). No, to do it right you need to spend an afternoon, or even a day, with a skilled tuner who can run the engine through a series of tests and tickle the edges safely to discover things. The second factor relates directly to the first: finding a skilled tuner that not only understands the concepts of dyno tuning but also understands the needs and desires of a 75-year-old air-cooled engine design. Sure, the basics are the same as other engines, but I suggest the edges are much much fuzzier. If I had someone with that talent in my area I'd absolutely leverage them. But I don't. I have some local guys that are good with their dynos but they're Honda guys, or Chevy guys; When I bring my 914 to them (and I have) they're glad to take my couple hours' money but other than tuning to my settings they're not really qualified to tickle (and if they're smart, they're not comfortable trying to tickle the unknown edges on a customer's car). So any dyno work I've done was to my AFR and ignition settings. And I really don't know what I'm doing either. I don't know what air-cooled dyno tuning experience there may be on this board, but I'd love to begin sharing some info on where we're going with these Micro/Mega installations. Where do these engines want to be? How much can (or should) we push them? What symptom(s) are we looking for to decide if we need more or less of anything? What's the sweet - and safe - spots? I'm atttaching my AFR target and ignition tables, let me know what you think. Am I in the ballpark? I'm not asking you for any secrets. I'm just looking for some feedback to understand if I'm setting myself up for problems in the future. This is not my race car, I'm not looking for that nth hp advance; this is my street car, one that gets driven only 3000 miles a year (if I'm lucky, especially lately). I want to enjoy it and not worry about it. And maybe I'll learn something in the process. And...discuss! - GA Attached image(s) ![]() ![]() |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
I dont run MS on my car but I figured I could post my tables and maybe there is something someone can learn from them. My engine is a 2256 cc, 10.3:1 compression running 40 mm ITB's so the table setup is reflecting that with Alpha-N and its running in wasted spark.
![]() ![]() The darker pink area in the ignition table is basically my cruise settings. Its usually done between 12-15% throttle opening. Cruise CHT temps is in the 280-330 range with cyl 1 being the hottest one and always 25-30 F higher than the others. ![]() I have a friend thats tuned it for me and the priorities was. 1. Safety (never lean, no detonation etc) 2. Driveability (wide torque range) 3. Power (connected to the above) 4. Milage 5. Emissions (only measured every two years and at idle) |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,103 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I dont run MS on my car but I figured I could post my tables and maybe there is something someone can learn from them. My engine is a 2256 cc, 10.3:1 compression running 40 mm ITB's so the table setup is reflecting that with Alpha-N and its running in wasted spark. ![]() I dont know about learning anything, but I can tell from your fuel map that your cam sure isnt stock!!! And I thought my motor was a screamer, that thing must be tons of fun once you hit 4k RPMs Are the 40mm TBs large enough to feed that thing? I tuned a 2270 with a milder cam and some smaller (i think 42mm) Jenvy ITBs and I could see a noticeable intake restriction in the datalogs. could have been his tiny air filters though. |
Lo-Fi Version | Time is now: 15th July 2025 - 09:16 AM |
