> Swap for 2.0 bus motor?, Swap questions
Mikey914
post Jan 5 2005, 10:10 PM
The rubber man
(IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) Well I've started another project. It's a 1975 1.8 that had an engine fire. It got so hot that the cooling shroud actually melted. Top end F/I is baked, and EEC appears to be in good condition, but I'm thinking baked also. My plan was to dissasemble and take to a machine shop to rebuild. All sheet metal is good, I'm sand blasting and shooting with etch primer now to repaint.
My question is this; will a 2.0 bus motor bolt in in place of the 1.8? I'm thinking I may need to do some work on the exhaust side, but other than that what should I expect?
Any thoughts?
P.S. I plan to go to carbs.
Dave_Darling
post Jan 6 2005, 12:02 PM
914 Idiot
If the Bus motor is late enough, the exhaust ports will be the wrong shape to bolt up to a 914 exhaust. The "square-port Vanagon" heads came on the 79+ 2.0 Bus, I think. (Could have the year wrong.) The difference in port shape should be obvious if you look at them.
--DD
- Lo-Fi Version Time is now: 1st August 2025 - 05:12 AM
