Turn signal indicator light, Only blinks once ... |
Chaznaster |
Nov 14 2021, 05:45 PM
Member Group: Members Posts: 302 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hi. I have been trying to troubleshoot the turn signal indicator light - the one on the speedo. It's a '74 so only one light that is supposed to blink regardless of the chosen direction. It is not worked since I have the car. The signals themselves and the hazards work fine.
Recently, I went through and replaced the dashboard bulbs and got nearly everything working. Not the turn signal, however. Interestingly, when I disconnect and connect the battery, then switch either the lever on the steering column or the hazards, the light comes on once (yay!) but then refuses to come on again (awww). My first thought is the hazard relay (the square one on the back of the fuse panel) might be bad. Before trying to replace it (I have read that the new ones are problematic), does anyone have any other suggestions? If not, what is the most reliable source for that relay these days?? Thank you. |
Jim C |
Nov 16 2021, 08:36 AM
Member Group: Members Posts: 193 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
Chaznaster, let me know if that relay fixes the problem please.
DRPHIL914 |
Nov 16 2021, 10:03 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
ClayPerrine |
Nov 16 2021, 12:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Chaznaster, let me know if that relay fixes the problem please. yes please do, i have this issue as well, but only on right side not left, and its just the indicator , the side flasher flashes just fine. Usually if it is only one side, it is a turn signal bulb is out. That is supposed to be an indicator of a bad bulb. Clay |
Lo-Fi Version | Time is now: 7th June 2024 - 03:03 PM |
