BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I want to swap my current 2.0 late plenum with an early 2.0 plenum and the larger diameter inlets (trying to get more air to my Raby cam on cold start). I'm sure it's possible to do this in the car, but how big of a PITA is it? I can't recall off the top of my head if you need to remove or loosen the L/R cylinder tin in order to get the plenum off.
I know I'll have to loosen up the intake runners, and negotiating the old one off of those and the new one back on is sometimes finicky, even with the engine out. I'm pretty decent dropping the engine, but what's the quickest way here (or, the path of least resistance (IMG:style_emoticons/default/smile.gif) )? |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,594 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Thank you for the explanation. Please share results and setup after you try it. I believe I bought a BMW unit too for my build but I am very far from getting all of this running... (IMG:style_emoticons/default/rolleyes.gif)
Good luck, I hope this will solve your problem. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 02:37 AM |
