> Dyno day, Now with figures!!!
emerygt350
post Nov 20 2021, 02:32 PM
Just got back from the Dyno. We were able to tune the mps reasonably well. Still have a little leanness at wot and lower rpms and richness at wot at high rpms but overall pretty smooth. Waiting to get the figures from the shop. If I remember right it was 77 horsepower and 105 lbs of torque at the wheels. I am running big 225/50r16s so I suspect I would pick up some more with lighter stock rims and tires....
I will post the graphs as soon as I get them.
Van B
post Nov 22 2021, 02:39 PM
More resistance in the plug means more energy build up before the spark can jump the gap. So, a more powerful can overcome the sparkplug resistance quicker and provide more arc energy to the spark itself... but there's a lot of other assumption on that as well: plug wires, etc. But treating the coil as a constant, a higher resistance plug can alter the actual spark timing just ever so slightly. Going to Coil On Plug (COP) is what gave manufacturers the ability to really tune engines for efficiency. Even differing length of plug wires varies resistance between cylinders.
Regardless, you want to be a little rich at high RPM and WOT... the last place you want detonation is during the most stressful parameters for engine operation. Being a little lean off the bottom can give a more snappy throttle response too. The problem you run into when trying to nail the AFR is that you have no forgiveness in the fuel. I'm sure we all run premo fuel, but let's say you fill up one day and the premium is 1 octane point lower than what you used for tuning and you dialed in a perfect 14.7:1 AFR... well now you have a detonation problem.
So, there's no point in running a street engine at 14:1 AFR. I'd like to know the ratios you were seeing at "a little lean, and a little rich" for my own curiosity. But if you're even 12:1, I'd say you're just fine.
emerygt350   Dyno day   Nov 20 2021, 02:32 PM
mgp4591   Just got back from the Dyno. We were able to tun...   Nov 20 2021, 03:18 PM
Shivers   So about 93 horsepower, plenty to be fun. (+-) Thi...   Nov 20 2021, 03:34 PM
emerygt350   Stock 73 2.0 djet. I do have an ansa muffler and ...   Nov 20 2021, 03:45 PM
Shivers   Great   Nov 20 2021, 04:55 PM
Van B   That’s so f***ing cool.   Nov 20 2021, 05:17 PM
emerygt350   Tom at overdrive automotive in Binghamton NY is gr...   Nov 20 2021, 05:42 PM
JamesM   Tom at overdrive automotive in Binghamton NY is g...   Nov 22 2021, 02:52 PM
PanelBilly   I want a video with sound!!   Nov 20 2021, 06:25 PM
emerygt350   I knew I should have taken a video... Stupid not ...   Nov 20 2021, 06:45 PM
Van B   Yes, yes you should have. And we are all very disa...   Nov 20 2021, 07:51 PM
emerygt350   Funny thing is everyone in the shop "knew...   Nov 20 2021, 08:17 PM
Van B   Deleted* I need to think more about what I was abo...   Nov 21 2021, 09:17 PM
emerygt350   It got super rich, black smoke everywhere. Lost 2...   Nov 22 2021, 08:52 AM
Van B   doesn't the 123 ignition let you create a cust...   Nov 22 2021, 09:17 AM
emerygt350   doesn't the 123 ignition let you create a cus...   Nov 22 2021, 09:32 AM
ValcoOscar   I just noticed the rear FUCHS spinning :willis...   Nov 22 2021, 09:20 AM
Van B   Maybe one step up on the plug heat range then?   Nov 22 2021, 11:47 AM
emerygt350   Maybe one step up on the plug heat range then? ...   Nov 22 2021, 12:37 PM
Van B   More resistance in the plug means more energy buil...   Nov 22 2021, 02:39 PM
emerygt350   I am still waiting on the graphs, that has the afr...   Nov 22 2021, 03:43 PM
Van B   When I checked my 1.8 yesterday, the red mark came...   Nov 22 2021, 04:31 PM
emerygt350   Finally got the graphs! I am color blind but ...   Nov 24 2021, 03:48 PM
JamesM   Finally got the graphs! I am color blind but...   Nov 24 2021, 09:04 PM
emerygt350   Yeah, the issue is adjusting at WOT. The mps is a...   Nov 24 2021, 09:17 PM
bkrantz   Can I ask how much you paid for how much time?   Nov 24 2021, 08:35 PM
emerygt350   Can I ask how much you paid for how much time? ...   Nov 24 2021, 08:57 PM
Van B   Other than the wavy A/F line on the last run, your...   Nov 24 2021, 08:40 PM
emerygt350   Other than the wavy A/F line on the last run, you...   Nov 24 2021, 08:58 PM
wonkipop   Other than the wavy A/F line on the last run, yo...   Nov 24 2021, 09:50 PM
Van B   @JamesM these are WOT. Part throttle will be much...   Nov 24 2021, 09:33 PM
JamesM   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 25 2021, 10:22 AM
emerygt350   Yeah, we were able to get part throttle tuned in p...   Nov 25 2021, 12:44 PM
JamesM   Yeah, we were able to get part throttle tuned in ...   Nov 25 2021, 06:36 PM
emerygt350   Yeah, we were able to get part throttle tuned in...   Nov 25 2021, 07:38 PM
wonkipop   RE: Dyno day   Nov 25 2021, 07:50 PM
emerygt350   Is that real or is that a model?   Nov 26 2021, 07:21 AM
wonkipop   Is that real or is that a model? i'm pr...   Nov 27 2021, 02:45 AM
- Lo-Fi Version Time is now: 16th November 2026 - 03:45 AM
