| JCP914 |
Nov 21 2021, 07:17 PM
Newbie ![]() Group: Members Posts: 3 Joined: 21-November 21 From: Indianapolis Member No.: 26,096 Region Association: None |
I am an amputee, I just purchased a 1972 914 and I need to convert it to an automatic. What is the best automatic and share how it can be done and where. I live in Indy.
| ejm |
Nov 22 2021, 12:51 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box.
| mgp4591 |
Nov 22 2021, 03:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,956 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box. 1.8T from an A4 automatic... Paging Andrew Dalen... (IMG:style_emoticons/default/driving.gif) |
| ValcoOscar |
Nov 22 2021, 03:26 PM
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,625 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California
While a /4 sporto would be cool there's lots to consider. A sporto box would likely be sourced from a 911 and would need the ring gear flipped. You also need to find a vacuum tank and servo, the special shifter with the electrical contacts and maybe a fluid reservoir since the /6 used the engine oil tank. You'd need to figure out how to circulate oil for the convertor. The /6 used a pump driven off the end of the camshaft but a pump was never developed for a 914/4. You may be able to use something like the double pump from a VW autostick but will likely run into clearance problems with the engine support bar like you do with a dry sump pump. A few of the reasons why I don't think we've ever seen a /4 converted to sportomatic. A full auto from an inline engine front wheel drive VW/Audi is much easier since everything is in the box. 1.8T from an A4 automatic... Paging Andrew Dalen... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/bye1.gif) @Andyrew |
JCP914 Automatic Transmission Nov 21 2021, 07:17 PM
flipb Thread by a member who had a 914 with an Audi auto... Nov 21 2021, 07:30 PM
Chris H. A Vanagon trans might work well. They initially h... Nov 21 2021, 07:41 PM
JCP914
I am an amputee, I just purchased a 1972 914 and ... Nov 21 2021, 07:55 PM
ClayPerrine If it were me, I would put in a sportomatic instea... Nov 22 2021, 06:47 AM
rgalla9146
If it were me, I would put in a sportomatic inste... Nov 22 2021, 10:15 AM
Superhawk996
If it were me, I would put in a sportomatic inste... Nov 23 2021, 09:53 AM
ClayPerrine
If it were me, I would put in a sportomatic inst... Nov 26 2021, 09:39 AM
930cabman
If it were me, I would put in a sportomatic inst... Nov 26 2021, 01:18 PM
stownsen914 I've got a Sportomatic core trans for sale, in... Nov 26 2021, 09:07 PM
Shivers https://www.ebay.com/itm/123851590716?chn=p...9xoC... Nov 22 2021, 07:53 AM
roblav1 No doubt... Sportomatic. Nov 22 2021, 08:16 AM
emerygt350 Sportomatic would be very cool. Nov 22 2021, 08:47 AM
Shivers I just found this on ebay: https://www.ebay.com/... Nov 22 2021, 10:25 AM
Andyrew
[quote name='mgp4591' post='2961678' date='Nov 22... Nov 22 2021, 09:15 PM
rgalla9146
While a /4 sporto would be cool there's lots ... Nov 22 2021, 07:03 PM
FlacaProductions Paging @dr914@autoatlanta.com Nov 22 2021, 12:51 PM
davep I hate raining on someones parade, but this does n... Nov 22 2021, 03:59 PM
emerygt350
I hate raining on someones parade, but this does ... Nov 22 2021, 04:00 PM
Chris H.
I hate raining on someones parade, but this does... Nov 22 2021, 07:12 PM
ejm
If you want to go backwards. The case design is ... Nov 22 2021, 07:22 PM
Highland Just an idea, but perhaps an EV conversion kit wou... Nov 22 2021, 04:13 PM
windforfun No no no. Sorry, but why even bother? Nov 22 2021, 07:03 PM
Shivers
Amputee. Nov 22 2021, 07:07 PM
windforfun
Amputee... Nov 22 2021, 07:09 PM
Shivers
[quote name='Shivers' post='2961726' date='Nov 22... Nov 22 2021, 07:12 PM
mepstein Electric conversion? Nov 22 2021, 08:45 PM
wonkipop
:) :agree:
bonus - goi... Nov 23 2021, 01:26 AM
Chris914n6 Nothing bolts up to the stock 1.7, so you are look... Nov 22 2021, 10:18 PM
76-914 I'd suggest a well built and sorted Subaru con... Nov 23 2021, 12:21 AM
mepstein And :wttc: Nov 23 2021, 08:59 AM
burton73 My wife had a 70-super beetle with an automatic st... Nov 30 2021, 04:12 PM
73-914
My wife had a 70-super beetle with an automatic s... Nov 30 2021, 04:45 PM
flyer86d I’m getting old and I forget a lot but didn’t ... Nov 30 2021, 05:39 PM
oldie914 I've got a copy of the 100 page tech informati... Dec 1 2021, 02:09 AM
rick 918-S What part of your body was amputated? Could you ad... Dec 1 2021, 05:47 AM
Shivers
What part of your body was amputated? Could you a... Dec 1 2021, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st June 2026 - 05:19 AM |
