| Fanmac |
Nov 23 2021, 12:00 PM
Newbie ![]() Group: Members Posts: 5 Joined: 23-November 21 From: SC Member No.: 26,102 Region Association: None |
Hello,
Please listen to the attached video and tell me what you think. It sounds like top end valve train noise, push rod? See links below, I appreciate your time. 914 1974 1.8 stock https://youtu.be/FjfgbFgZY64 Thanks. |
| wonkipop |
Nov 23 2021, 06:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
ah no i see its #4.
still it seems like maybe its back from the fan that you are hearing it. over in the area above #4. still as above suggestion, you are not hearing a noise come up that open heating air riser from the heat exchangers? i notice its got no cap seal on it or blower fan hook up. could channel noise? EDIT another thought for noise in that area. cooling flap has failed in some way? that one in the ducting in oil cooler area has a clip like connection. broken and the flap is rattling in the airstream? watch this video. i think no matter what it will fail in fail safe position for air flow. but it could bounce and rattle around if it looses its fastening. https://www.youtube.com/watch?v=Q2_dzR1qJ6A |
Fanmac Engine Noise: Stumped! Nov 23 2021, 12:00 PM
Shivers :confused:
Nov 23 2021, 12:19 PM
Fanmac It's fixed, please try again. Nov 23 2021, 01:09 PM
Shivers I'm hearing a lot of noises, but one sounds fr... Nov 23 2021, 02:21 PM
Robarabian Something in the fan shroud... blowing around.. I ... Nov 23 2021, 02:44 PM
Van B The engine sounds too smooth and steady for it to ... Nov 23 2021, 05:40 PM
wonkipop
The engine sounds too smooth and steady for it to... Nov 23 2021, 06:21 PM
Van B That’s a good theory about the cooling flap Wonk... Nov 23 2021, 09:42 PM
914sgofast2 The proverbial lost 10mm socket kicking around in ... Nov 23 2021, 10:24 PM
930cabman
The proverbial lost 10mm socket kicking around in... Nov 24 2021, 06:02 AM
Fanmac Wow!! Thanks for all the replies. I'm ... Nov 24 2021, 07:20 AM
bretth Mouse carcass flopping around in air ducts? Nov 24 2021, 12:18 AM
iankarr @wonkinpop. You should be a doctor with those diag... Nov 24 2021, 09:32 AM
Fanmac Ok, removed the tinware and got into the shroud. F... Nov 24 2021, 10:00 AM
rjames Maybe remove the valve cover and check for a broke... Nov 24 2021, 11:27 AM
wonkipop
Maybe remove the valve cover and check for a brok... Nov 24 2021, 02:10 PM
Wew +me on the push rod to rocker spacing. too loose.... Nov 24 2021, 02:38 PM
Fanmac Well, we checked everything listed above and still... Dec 1 2021, 10:45 AM
rfinegan Sounds like an exhaust noise to me...look for leak... Dec 1 2021, 11:22 AM
rgalla9146 Run the engine with the alternator belt off...see ... Dec 1 2021, 11:35 AM
wonkipop :(
when you find out report back.
interested 1.8... Dec 2 2021, 03:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:45 PM |
