> main bearings, preferred manufacturer
930cabman
post Nov 27 2021, 09:55 AM
I recently purchased a standard size main bearing set from a large vendor, checking the clearances I am finding this new set will provide a clearance at the high limit per factory specs. My crank is spot on, but the main bearing ID appears too large. I can easily fit a .004 feeler between the crank and new bearing ID. Just for fun, I tried an old (used)main bearing and found it to have a smaller ID (by about .0015) than a new one. Am I missing something?
Thanks
914Sixer
post Nov 27 2021, 01:37 PM
You have to remember that your old bearing shell has been crushed when you put the block together. Your new bearing has not had that happen yet. Size will change after crush.
- Lo-Fi Version Time is now: 27th October 2026 - 09:45 AM
