> 914World Classifieds Rules
> FS: Parts Stash, Calipers, Gauges, 911 Crossmember, SBC-901 kit, more
FL000
post Nov 27 2021, 06:10 PM
Decided to stop hoarding extra parts. All prices are plus shipping. If you need more info or pics let me know. Everything is as shown.
1. 911 wide A calipers, rebuilt, low mileage $200/pair - sold
2. 914-4 rear calipers, $100/pair - sold
3. 24 mm 911 rotors, $40/pair
4. 914-4 rear rotors, drilled for 5 lug, $40/pair - sold
5. 911 front dust shields, $20/pair
6. 914 rear dust shields, $20/pair - sold
7. Gauge cluster (combo, tach, Speedo, panel), $100 - sold
8. Individual gauges $20 each - fuel, volt, temp gauge sold
9. 911 crossmember, $200 - sold
10. 5 x 130 x 1” aluminum spacers and lug nuts, $60/pair
11. Side shifter, $50 - sold
12. Dash defroster vents, $20/pair, small break on one but looks functional
13. SBC to 901 kit (engine to trans adapter, flywheel, pressure plate, clutch disk, starter), for 2 piece rear main seal type, $500
14. Renegade SBC water pump and mount, $60 - sold
sb914
post Nov 28 2021, 09:19 AM
Surf Guru
I’m down for the starter as well if you want to sell separate?
Thanks josh…
FL000   FS: Parts Stash   Nov 27 2021, 06:10 PM
FlacaProductions   Messaged you   Nov 27 2021, 08:18 PM
mepstein   I’ll take the 911 crossmember if still available...   Nov 27 2021, 08:52 PM
HIPPIEKILLER   I position myself in case Mark passes or want to r...   Nov 29 2021, 11:18 AM
Steve   I’ll take fuel gauge and 914 5 bolt rear disks.   Nov 27 2021, 08:57 PM
abes914   I’ll take the rear calipers if for late model. ...   Nov 27 2021, 09:00 PM
Literati914   Put me down for #4 drilled rotors if they're a...   Nov 27 2021, 09:45 PM
orrzone   Interested in gauge cluster and shifter Will you ...   Nov 28 2021, 12:47 AM
FL000   Interested in gauge cluster and shifter Will you...   Nov 28 2021, 10:59 AM
ValcoOscar   @sb914   Nov 28 2021, 08:38 AM
sb914   I’ll take the waterpump and bracket. I was going...   Nov 28 2021, 09:01 AM
FL000   I’ll take the waterpump and bracket. I was goin...   Nov 28 2021, 11:03 AM
sb914   I’ll take the waterpump and bracket. I was goi...   Nov 29 2021, 08:35 AM
sb914   Thanks for the heads up Oscar   Nov 28 2021, 09:02 AM
sb914   I’m down for the starter as well if you want to ...   Nov 28 2021, 09:19 AM
FL000   A picture of the back of the clock that was reques...   Nov 28 2021, 10:27 AM
roundtwo   I’d like the small volt and temp gauge if availa...   Nov 29 2021, 12:20 PM
FL000   I’d like the small volt and temp gauge if avail...   Nov 29 2021, 08:43 PM
Hoppie944s2   .Ill take if not sold... Gauge cluster (combo, tac...   Nov 29 2021, 12:33 PM
roundtwo   Thank you. I’ll take them with LEDS. Pm sent. T...   Nov 30 2021, 12:21 PM
Andrew914   Interested in the temperature gauge if still avail...   Nov 30 2021, 12:25 PM
The Double S   PM Sent. Interested in the Cross Member if still a...   Nov 30 2021, 01:11 PM
Beach914   Interested in the clock if available   Dec 30 2021, 02:09 PM
FL000   @bossboy302 here are some more pics of the front ...   Jan 7 2022, 05:13 PM
- Lo-Fi Version Time is now: 3rd November 2026 - 03:29 AM
