| wonkipop |
Nov 25 2021, 04:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,761 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
@StarBear & @wonkipop want to hear from members who own 1974 1.8s.
to assist with a topic in originality section of the website. Cars need to be reasonably original with L jet fuel injection system intact. If you have the time and can help us with some information it would be great. information. 1. Vin Date - month and year (no need to post vin numbers if you don't want to). thats the date on the driver door sticker. 2. Karmann plate #. or if you have already done the maths, the day and week of the year the car began production. 3. Image of engine bay emission sticker (lhs above the air cleaner - white with red letters). sticker should say whether it is an EC-A or an EC-B engine and whether it is california + EPA or only EPA. 4. image of engine tune up sticker. this is the small white sticker that is on LHS engine tin just below fan shroud. most of them are gone by now, but some engines still have them. 5. image of the throttle body. image of the distributor. we are looking at the vacuum hose set up between the distributor and the throttle body. ----- (IMG:style_emoticons/default/beerchug.gif) |
| wonkipop |
Nov 28 2021, 03:33 PM
@L-Jet914
i think i have figured out what the modification on yours does and why it might have been done. its someone's idea of how to cancel retard at standing idle. the basic idea would be the advance on the dist is being pulled at idle and counteracts the pull in opposite direction from retard. retard at idle was an emissions thing. it made combustion cooler for lower NOx emission. the plumbing in the modification possibly also changes the way the distributor comes off advance as you deaccelerate. someone has done it because they believe it makes it drive a bit sweeter is my guess. it probably does, you are driving it. the only way to know what its doing would be to drive another 914 with the original set up and compare alongside. stuff gets done to these cars. esp. these ones with the first real smog engines. EDIT actually i might have that the wrong way around, re-reading your original description. it seems they have gone for a different source of vacuum for the retard than the throttle body? and maybe took the factory cap off the advance port and put it on the retard port. and connected up advance when it was never connected. could be as simple as that. some-one familiar with the EC-B engines looked at this one and decided it was "wrong" so they made an EC-B style set up? |
| L-Jet914 |
Nov 28 2021, 09:04 PM
Member ![]() ![]() Group: Members Posts: 428 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
@L-Jet914 i think i have figured out what the modification on yours does and why it might have been done. its someone's idea of how to cancel retard at standing idle. the basic idea would be the advance on the dist is being pulled at idle and counteracts the pull in opposite direction from retard. retard at idle was an emissions thing. it made combustion cooler for lower NOx emission. the plumbing in the modification possibly also changes the way the distributor comes off advance as you deaccelerate. someone has done it because they believe it makes it drive a bit sweeter is my guess. it probably does, you are driving it. the only way to know what its doing would be to drive another 914 with the original set up and compare alongside. stuff gets done to these cars. esp. these ones with the first real smog engines. EDIT actually i might have that the wrong way around, re-reading your original description. it seems they have gone for a different source of vacuum for the retard than the throttle body? and maybe took the factory cap off the advance port and put it on the retard port. and connected up advance when it was never connected. could be as simple as that. some-one familiar with the EC-B engines looked at this one and decided it was "wrong" so they made an EC-B style set up? So what you're saying is that according to my tune up sticker, the vac advance side of the distributor was not supposed to be hooked up to the rear port facing the trunk of the throttle body (I've checked no vacuum until off idle at the rear port and manifold vacuum at the forward facing port)? I've only driven the car as you see pictured in the engine bay. I never drove the car prior to any engine work etc. I would love to see a EC-A setup L-Jet engine in bone stock configuration to see if I should remove the added vacuum t and route the retard side of the distributor to the manifold vacuum side of the throttle body. This thread is becoming more and more interesting as I've read through this. |
| wonkipop |
Nov 29 2021, 02:42 AM
@L-Jet914 i think i have figured out what the modification on yours does and why it might have been done. its someone's idea of how to cancel retard at standing idle. the basic idea would be the advance on the dist is being pulled at idle and counteracts the pull in opposite direction from retard. retard at idle was an emissions thing. it made combustion cooler for lower NOx emission. the plumbing in the modification possibly also changes the way the distributor comes off advance as you deaccelerate. someone has done it because they believe it makes it drive a bit sweeter is my guess. it probably does, you are driving it. the only way to know what its doing would be to drive another 914 with the original set up and compare alongside. stuff gets done to these cars. esp. these ones with the first real smog engines. EDIT actually i might have that the wrong way around, re-reading your original description. it seems they have gone for a different source of vacuum for the retard than the throttle body? and maybe took the factory cap off the advance port and put it on the retard port. and connected up advance when it was never connected. could be as simple as that. some-one familiar with the EC-B engines looked at this one and decided it was "wrong" so they made an EC-B style set up? So what you're saying is that according to my tune up sticker, the vac advance side of the distributor was not supposed to be hooked up to the rear port facing the trunk of the throttle body (I've checked no vacuum until off idle at the rear port and manifold vacuum at the forward facing port)? I've only driven the car as you see pictured in the engine bay. I never drove the car prior to any engine work etc. I would love to see a EC-A setup L-Jet engine in bone stock configuration to see if I should remove the added vacuum t and route the retard side of the distributor to the manifold vacuum side of the throttle body. This thread is becoming more and more interesting as I've read through this. yes, thats what i understand the tune up sticker to mean. our EC-B cars have a tune up sticker with both hoses shown and shown disconnected for timing at idle. its interesting when you look at something like a 2.0L they have i believe both hoses shown connected for the timing. it would in fact be easy to make yours an EC-B. you just plug the retard line directly into the retard port on the throttle body and take the cap off. thats what i think. but you have a form of manifold vacuum on the retard so why upset the apple cart. in a way you already have an EC-B set up. we would also love to see a bone stock EC-A setup. we are guessing what it is off the tune up sticker and description by @ClayPerrine . his description of how he believes L jet ought to be set up seems to accord with EC-A. --- the weird thing is the texas twin car probably came off the line the same day as mine. given its 30 numbers on in the VIN and mine is about the middle of a day's production. i forget the exact number. mine is around 45th car for the day. so the texas twin is probably right at the end of the day. so they are building EC-A and EC-B on the same day. and the funny thing is the dealers could easily have made an EC-B into an EC-A by just unplugging the advance and capping it and vise versa. as far as i can tell. maybe there is more to it. i don't know. |
wonkipop Members with 74 1.8 Nov 25 2021, 04:35 PM
StarBear Especially if your 1.8L was built in late 73 or th... Nov 25 2021, 05:46 PM
JeffBowlsby Would be helpful to add some samples of these labe... Nov 25 2021, 08:55 PM
wonkipop emission sticker.
tune up sticker
throt... Nov 25 2021, 10:03 PM
Arno914 You probably know this already: Only US 1.8l 914´... Nov 26 2021, 02:19 AM
wonkipop
You probably know this already: Only US 1.8l 914Â... Nov 26 2021, 03:34 AM
Van B Jeff, good idea for posting an example. It gave me... Nov 26 2021, 12:05 PM
wonkipop @Van B
thanks mate. gold. :beer2:
(you mig... Nov 26 2021, 03:43 PM
Van B I have not worked that out. Would you mind breakin... Nov 26 2021, 05:15 PM
wonkipop
I have not worked that out. Would you mind breaki... Nov 26 2021, 05:40 PM
RRietman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 26 2021, 05:57 PM
wonkipop @RRietman
thanks mate. :beer2:
EDIT.
just t... Nov 26 2021, 06:00 PM
StarBear
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 26 2021, 06:09 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?... Nov 26 2021, 07:02 PM
RRietman
[quote name='StarBear' post='2962812' date='Nov 2... Nov 27 2021, 02:46 PM
Shivers I have one of these but it is just a tub, nothing ... Nov 26 2021, 07:37 PM
wonkipop
I have one of these but it is just a tub, nothing... Nov 26 2021, 07:43 PM
wonkipop
I have one of these but it is just a tub, nothing... Nov 26 2021, 07:48 PM
Shivers
I have one of these but it is just a tub, nothin... Nov 26 2021, 07:52 PM
ClayPerrine
I have one of these but it is just a tub, nothin... Nov 27 2021, 02:32 AM
Shivers
[quote name='wonkipop' post='2962842' date='Nov 2... Nov 27 2021, 08:31 AM
Shivers I registered the VIN here under the name So.Cal.91... Nov 26 2021, 07:51 PM
Van B I'm gonna start calling you Shivers the thread... Nov 27 2021, 09:10 AM
Shivers Aaarrrg Nov 27 2021, 09:27 AM
wonkipop @Shivers
thanks for the can info, looked up the c... Nov 27 2021, 04:50 PM
Shivers Sorry I couldn't help.
@wonkipop Nov 27 2021, 05:07 PM
wonkipop
[b]@[url=http://www... Nov 27 2021, 05:14 PM
L-Jet914 Here is the data from my 1974 1.8L L-jet. Stock FI... Nov 27 2021, 09:28 PM
L-Jet914 More photos Nov 27 2021, 09:29 PM
Van B Oh the guys are gonna be so happy when they see th... Nov 27 2021, 11:40 PM
wonkipop STOKED
:beer2:
mr. b is going to be happy too.... Nov 27 2021, 11:55 PM
L-Jet914
STOKED
:beer2:
mr. b is going to be happy too... Nov 27 2021, 11:58 PM
wonkipop
STOKED
:beer2:
mr. b is going to be happy to... Nov 28 2021, 12:09 AM
StarBear
STOKED
:beer2:
mr. b is going to be happy too... Nov 28 2021, 08:21 AM
wonkipop
STOKED
:beer2:
mr. b is going to be happy to... Nov 28 2021, 03:12 PM
Van B Based on my trials, I would wager that the ECU is ... Nov 28 2021, 12:15 AM
nihil44 My contribution. Imported into Aus in 1990. Conver... Nov 28 2021, 12:34 AM
wonkipop
Based on my trials, I would wager that the ECU is... Nov 28 2021, 12:46 AM
wonkipop
Based on my trials, I would wager that the ECU is... Nov 28 2021, 05:27 AM
wonkipop
Based on my trials, I would wager that the ECU is... Dec 1 2021, 04:41 PM
wonkipop @nihil44
i was waiting for you to come through.
... Nov 28 2021, 12:40 AM
L-Jet914 I don't why the vacuum T was installed in betw... Nov 28 2021, 12:54 AM
wonkipop
I don't why the vacuum T was installed in bet... Nov 28 2021, 03:11 PM
wonkipop @L-Jet914 don't worry as to what or the why y... Nov 28 2021, 03:05 AM
Porschef @Big Len Nov 28 2021, 08:45 AM
wonkipop @nihil44
yours is real interesting.
theoretical... Nov 28 2021, 03:16 PM
wonkipop another member here working on the texas twins has... Nov 28 2021, 04:19 PM
StarBear
another member here working on the texas twins ha... Nov 28 2021, 04:30 PM
wonkipop
another member here working on the texas twins h... Nov 28 2021, 04:57 PM
Van B http://www.914world.com/bbs2/uploads/post-...65737... Nov 28 2021, 10:40 PM
Big Len Here's a few pics of my 1.8. I don't see a... Nov 29 2021, 12:26 PM
Big Len RE: Members with 74 1.8 Nov 29 2021, 12:28 PM
Big Len RE: Members with 74 1.8 Nov 29 2021, 12:29 PM
Big Len RE: Members with 74 1.8 Nov 29 2021, 12:30 PM
Van B @Big Len
First, your car looks incredible man, I... Nov 29 2021, 01:14 PM
Big Len
@Big Len
First, your car looks incredible man, I... Nov 29 2021, 01:47 PM
wonkipop
@Big Len
First, your car looks incredible man, I... Nov 29 2021, 03:58 PM
StarBear
@Big Len
First, your car looks incredible man, I... Nov 29 2021, 05:24 PM
wonkipop thanks for posting up @Big Len
very nice looking c... Nov 29 2021, 03:40 PM
Van B It’s covered in overspray from a paint job that ... Nov 29 2021, 04:56 PM
Van B @StarBear
Got the paper, thanks bud!
How are ... Nov 29 2021, 08:59 PM
StarBear
@[url=http://www.914world.com/bbs2/index.php?show... Nov 30 2021, 07:05 AM
wonkipop just found another member here on the vin list thr... Nov 29 2021, 09:43 PM
Van B Wait, EC-B is the 49 state setup. My car was never... Nov 29 2021, 09:59 PM
wonkipop
Wait, EC-B is the 49 state setup. My car was neve... Nov 29 2021, 10:05 PM
wonkipop here is the sticker for the mythical car.
Nov 29 2021, 10:10 PM
Van B Well, ok, but not tonight. Do you know Mr. Researc... Nov 29 2021, 10:17 PM
wonkipop i am as dumb as all you guys when it comes to poll... Nov 29 2021, 10:27 PM
wonkipop re 49 state cars.
theoretically given that only c... Nov 29 2021, 10:34 PM
wonkipop RE: Members with 74 1.8 Nov 29 2021, 10:42 PM
Van B Well, I guess I’ll get my lucky underseat quarte... Nov 29 2021, 11:00 PM
wonkipop this is the only other thing i know about US smog ... Nov 29 2021, 11:26 PM
L-Jet914
this is the only other thing i know about US smog... Nov 30 2021, 12:14 AM
wonkipop van - USA emissions regs ran on MY for cars was th... Nov 29 2021, 11:42 PM
Van B I agree about the model year applicability, but th... Nov 30 2021, 12:09 AM
wonkipop
I agree about the model year applicability, but t... Nov 30 2021, 12:46 AM
L-Jet914 CARB EO A-7-5 which has since been rescinded and A... Nov 30 2021, 12:31 AM
wonkipop nice stuff @L-Jet914
there are all sorts of fol... Nov 30 2021, 12:44 AM
L-Jet914
nice stuff [b]@[url=http://www.914world.com/bbs2... Nov 30 2021, 01:44 AM
wonkipop
nice stuff [b]@[url=http://www.914world.com/bbs... Nov 30 2021, 02:10 AM
wonkipop @L-Jet914
that really is the japanese gold of be... Nov 30 2021, 12:51 AM
wonkipop those EC-d or is it EC-D (whatever) - they had EGR... Nov 30 2021, 01:07 AM
Van B I'm curious if the signature dates on those fo... Nov 30 2021, 01:18 AM
wonkipop there is something going on - thats for sure. Nov 30 2021, 01:28 AM
wonkipop ok @[url=http://www.914world.com/bbs2/index.php?... Nov 30 2021, 02:38 AM
wonkipop found where LJet914 got the California Air Resourc... Nov 30 2021, 11:54 AM
Van B shouldn't you be asleep?! Nov 30 2021, 12:57 PM
wonkipop
yeah, should ... Nov 30 2021, 04:26 PM
JeffBowlsby The CA-only decal for the side windows was probabl... Nov 30 2021, 02:17 PM
wonkipop @JeffBowlsby .
thanks for those windscreen decels... Nov 30 2021, 05:10 PM
L-Jet914 @wonkipop You are correct the A-7-5-A is the revi... Nov 30 2021, 10:37 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 30 2021, 11:10 PM
wonkipop i cracked the Executive Order open a little bit mo... Dec 1 2021, 01:21 AM
wonkipop i think i have worked out this emission sticker th... Dec 1 2021, 05:05 PM
Van B Ok, so I’m following everything but the fact tha... Dec 1 2021, 05:53 PM
wonkipop
Ok, so I’m following everything but the fact th... Dec 1 2021, 06:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th October 2026 - 06:46 PM |
