| FL000 |
Nov 27 2021, 06:10 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California
Decided to stop hoarding extra parts. All prices are plus shipping. If you need more info or pics let me know. Everything is as shown.
1. 911 wide A calipers, rebuilt, low mileage $200/pair - sold 2. 914-4 rear calipers, $100/pair - sold 3. 24 mm 911 rotors, $40/pair 4. 914-4 rear rotors, drilled for 5 lug, $40/pair - sold 5. 911 front dust shields, $20/pair 6. 914 rear dust shields, $20/pair - sold 7. Gauge cluster (combo, tach, Speedo, panel), $100 - sold 8. Individual gauges $20 each - fuel, volt, temp gauge sold 9. 911 crossmember, $200 - sold 10. 5 x 130 x 1” aluminum spacers and lug nuts, $60/pair 11. Side shifter, $50 - sold 12. Dash defroster vents, $20/pair, small break on one but looks functional 13. SBC to 901 kit (engine to trans adapter, flywheel, pressure plate, clutch disk, starter), for 2 piece rear main seal type, $500 14. Renegade SBC water pump and mount, $60 - sold ![]() Attached image(s)
| roundtwo |
Nov 29 2021, 12:20 PM
Member ![]() ![]() Group: Members Posts: 372 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California
I’d like the small volt and temp gauge if available. A little hard to tell by the picture but they look to be in decent condition.
Pm sent |
FL000 FS: Parts Stash Nov 27 2021, 06:10 PM
FlacaProductions Messaged you Nov 27 2021, 08:18 PM
mepstein I’ll take the 911 crossmember if still available... Nov 27 2021, 08:52 PM
HIPPIEKILLER I position myself in case Mark passes or want to r... Nov 29 2021, 11:18 AM
Steve I’ll take fuel gauge and 914 5 bolt rear disks. Nov 27 2021, 08:57 PM
abes914 I’ll take the rear calipers if for late model. ... Nov 27 2021, 09:00 PM
Literati914 Put me down for #4 drilled rotors if they're a... Nov 27 2021, 09:45 PM
orrzone Interested in gauge cluster and shifter
Will you ... Nov 28 2021, 12:47 AM
FL000
Will you... Nov 28 2021, 10:59 AM
ValcoOscar @sb914 Nov 28 2021, 08:38 AM
sb914 I’ll take the waterpump and bracket. I was going... Nov 28 2021, 09:01 AM
FL000
I’ll take the waterpump and bracket. I was goin... Nov 28 2021, 11:03 AM
sb914
I’ll take the waterpump and bracket. I was goi... Nov 29 2021, 08:35 AM
sb914 Thanks for the heads up Oscar Nov 28 2021, 09:02 AM
sb914 I’m down for the starter as well if you want to ... Nov 28 2021, 09:19 AM
FL000 A picture of the back of the clock that was reques... Nov 28 2021, 10:27 AM
FL000
I’d like the small volt and temp gauge if avail... Nov 29 2021, 08:43 PM
Hoppie944s2 .Ill take if not sold... Gauge cluster (combo, tac... Nov 29 2021, 12:33 PM
roundtwo Thank you. I’ll take them with LEDS. Pm sent. T... Nov 30 2021, 12:21 PM
Andrew914 Interested in the temperature gauge if still avail... Nov 30 2021, 12:25 PM
The Double S PM Sent. Interested in the Cross Member if still a... Nov 30 2021, 01:11 PM
Beach914 Interested in the clock if available Dec 30 2021, 02:09 PM
FL000 @bossboy302 here are some more pics of the front ... Jan 7 2022, 05:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 03:30 AM |
