> Another stupid d-jet question:, Related to a new 2.1 tune: defining terms- what constitutes "part-load vs full-load" and other mysteries
DRPHIL914
post Nov 29 2021, 08:06 AM
Dr. Phil
calling all d-jet masters !
OK so yes, ive read Anders etc and maybe missed it along the way, but
how or what constitutes a part-load condition?
I am trying to get my d-jet MPS dialed in on the 2.1 build. and it had been running really well, but just a tad lean still, so after going back and reverifying my timing and other settings, checking plugs aftera 750 mile trip, its really close and realizing i was probably a bit low on the fuel pressure i made that correction and then set out to do some local highway driving to test it out, and really felt good, but maybe a bit rich at low end, idle and what i was thinking would be part-load.
BUT i think i over corrected on the MPS and now i went from being in the 12-12.5 range at idle and also cruising at 3000-3400rpm, i now am running light at about 14 on that mid-range cruising. it is good on WOT so i dont want to mess with that(full load stop) .
i should have left well enough alone because i will probably be a bit heavy at idle and low end with this motor, due to a more performance minded cam profile etc.
point is, what is part-load? if i am reading my AFR meter , lets say at 3000rpm- 3400rpm and cruising on the flat, that would be part- load condition correct? so i dont want to make it more rich at cruise or on WOT, so how can i isolate the mid range or par-load to enrich it with out messing anything else up. i already messed this up trying to just lean it out slighty and over corrected.
if i adjust the inner screw by itself it changes both part and full load.
the outer screw in will richen part load i believe lean out full- load.
the Anders chart doesnt really address it.
- also i feel i cant really get idle right, it seems too rich but that might be the way the motor will be, not sure.
the MPS is a rebuilt one with Tangerine kit and adjustor screws, so easy to access and adjust using the Tangerine tools.
I may be at the point of just going dual webber with 44 IDF's, and forsaking the d-jet - OR a more modern programable EFI...... i just dont think i am getting the most power out of this motor that i should or would with better air intake and A/F mix.
intake is somewhat restricted on a stock d-jet and the injectors can only give you so much fuel. i did see somewhere anders wrote that the stock set up could support a build up to 2270 even with the proper changes( not sure what that means either),
anyway first question is - part load definition. then how to proceed to get this mid-range or par-load adjusted into a better mix with out making idle even more rich(or WOT either)
Thanks for the help.
Phil
DRPHIL914
post Nov 29 2021, 11:16 AM
Dr. Phil
here are 2 plugs, this was before input them back in and then attempted to adjust the setting and messed it up.
- also my head temps and oil temp readings i think are accurate and are pretty good , not sure i am believe or knowing how accurate the AF readings are, it the plugs should give a good idea of where i was.
emerygt350
post Nov 29 2021, 11:24 AM
Those look good to me. I just did a deep dive into previous threads on this topic. Very interesting. Things I dredged up from the past... (may just be urban legends but I doubt it)
1) Air-cooled engines like it richer
2) 14 and less seems good
3) 12 at WOT seems good
4) Don't go driving around at 15 particularly while in 5th gear at lower rpms.
5)13.5 at idle is common and seems like a happy place, some people go richer.
Let the engine decide what it likes (assuming you aren't going north of 14 at partial load or 13 at WOT).
DRPHIL914
post Nov 29 2021, 12:45 PM
Dr. Phil
QUOTE(emerygt350 @ Nov 29 2021, 12:24 PM) *
i agree with that , it seems to be where we want to be. i do think i am a bit rich at idle and i cant adjust the ECU more than it is. i may have to settle for that. I am more like 12.5-13 at idle. just a very low idle too, i have to open up the idle air valve to keep it from bottoming out once warmed up. it had a good cold idle.
i should have left well enough alone. going to work on getting it back to where it was.
DRPHIL914   Another stupid d-jet question:   Nov 29 2021, 08:06 AM
BeatNavy   Phil, a couple of thoughts from me. @Frank S , ...   Nov 29 2021, 08:42 AM
emerygt350   same boat here but with a stock 2.0. When we fini...   Nov 29 2021, 10:19 AM
DRPHIL914   i do appreciate the input. and i can post a few pi...   Nov 29 2021, 10:48 AM
914_teener   calling all d-jet masters ! OK so yes, ive r...   Nov 29 2021, 11:08 AM
DRPHIL914   here are 2 plugs, this was before input them back...   Nov 29 2021, 11:16 AM
emerygt350   Those look good to me. I just did a deep dive int...   Nov 29 2021, 11:24 AM
DRPHIL914   Those look good to me. I just did a deep dive in...   Nov 29 2021, 12:45 PM
emerygt350   stock ignition?   Nov 29 2021, 01:06 PM
DRPHIL914   stock ignition? 123ignition distributor but st...   Nov 29 2021, 01:13 PM
emerygt350   stock ignition? 123ignition distributor but s...   Nov 29 2021, 03:15 PM
DRPHIL914   [quote name='DRPHIL914' post='2963462' date='Nov ...   Nov 29 2021, 08:03 PM
adolimpio   Here's a point of reference for what it's ...   Nov 29 2021, 08:53 PM
DRPHIL914   @[url=http://www.914world.com/bbs2/index.php?showu...   Nov 30 2021, 08:47 AM
emerygt350   I have an LCR and as others have said, your mileag...   Nov 30 2021, 10:16 AM
adolimpio   I should have mentioned that my compression is 8.2...   Nov 30 2021, 09:12 PM
914_teener   Here's a point of reference for what it's...   Dec 1 2021, 12:49 PM
emerygt350   Just put the AFR on mine and did some tuning. Got...   Dec 1 2021, 02:34 PM
DRPHIL914   Here's a point of reference for what it...   Dec 2 2021, 08:17 AM
914_teener   [quote name='914_teener' post='2963964' date='Dec...   Dec 2 2021, 07:32 PM
rjames   That seems a lot leaner than what I've heard...   Nov 30 2021, 12:29 AM
emerygt350   That seems a lot leaner than what I've hear...   Nov 30 2021, 07:56 AM
emerygt350   Once the AFR is in I can see how that sign wave...   Nov 30 2021, 08:03 AM
DRPHIL914   That seems a lot leaner than what I've hea...   Nov 30 2021, 08:38 AM
BeatNavy   :agree: with this and with Rob's ( @914_Teene...   Dec 1 2021, 06:55 AM
DRPHIL914   :agree: with this and with Rob's ( [b]@[url=...   Dec 2 2021, 08:47 AM
emerygt350   I bet you are a bit low on your timing. Have you ...   Dec 2 2021, 09:09 AM
DRPHIL914   I bet you are a bit low on your timing. Have you...   Dec 2 2021, 02:29 PM
BeatNavy   one other factor thats going to effect that is th...   Dec 2 2021, 03:03 PM
JamesM   one other factor thats going to effect that is t...   Dec 2 2021, 04:49 PM
emerygt350   As I have zeroed in on good mixtures across partia...   Dec 2 2021, 04:20 PM
- Lo-Fi Version Time is now: 7th June 2026 - 02:03 PM
