| NARP74 |
Nov 30 2021, 12:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,574 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
My car had been wrecked in the past and had a new front end grafted on. Probably during its race years. When they put the new front end on, it did not have any ground studs where the headlights are.
As a fix, they just used a sheet metal screws for the ground and put it through the fender well. As a result, a couple ground wires are just floating in air not connected because they can not reach the sheet metal screw. I want to hook them up as they should be. Is there an early v late version of the ground studs and location? |
| VaccaRabite |
Nov 30 2021, 02:26 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,921 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
There isn't a ground stud in the nose of the car. BUt the ground wires get looped into bolts and ground that way.
What wires are hanging free? Many of the headlight ground wires wires go to the bolt holes that hold the plastic covers for the headlight actuator arms. Zach |
NARP74 Ground Studs Nov 30 2021, 12:16 PM
NARP74
There isn't a ground stud in the nose of the ... Nov 30 2021, 05:50 PM
NARP74 This dropped fast. Anyone else? Dec 1 2021, 11:50 AM
Olympic 914 My '73 has Ground studs in the same place as p... Dec 1 2021, 03:18 PM
NARP74 It's strange but my grafted on front end did n... Dec 1 2021, 03:26 PM
914e Are you looking for these ground tabs? this is a 7... Dec 2 2021, 02:47 PM
NARP74 I guess I will just drill a hole and use a suitabl... Dec 3 2021, 12:22 PM
NARP74 Found this from Bowlsby, don't know if it is y... Dec 14 2021, 11:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 02:45 AM |
