| 930cabman |
Nov 27 2021, 09:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,871 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I recently purchased a standard size main bearing set from a large vendor, checking the clearances I am finding this new set will provide a clearance at the high limit per factory specs. My crank is spot on, but the main bearing ID appears too large. I can easily fit a .004 feeler between the crank and new bearing ID. Just for fun, I tried an old (used)main bearing and found it to have a smaller ID (by about .0015) than a new one. Am I missing something?
Thanks |
| iankarr |
Nov 27 2021, 04:06 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
There's been lots of talk about quality beinig all over the place with new bearings. I had to go through two sets of Silverline before we had a workable combo. Tabari Andrade on the samba has a line on new german bearings which look promising.
| AndradeT |
Nov 28 2021, 09:35 PM
Newbie ![]() Group: Members Posts: 1 Joined: 23-February 21 From: Los Angeles, CA Member No.: 25,252 Region Association: Southern California |
| iankarr |
Nov 30 2021, 11:01 PM
There's been lots of talk about quality beinig all over the place with new bearings. I had to go through two sets of Silverline before we had a workable combo. Tabari Andrade on the samba has a line on new german bearings which look promising. Thanks again Ian! Is this really your first post @andradeT ? I'm honored (IMG:style_emoticons/default/wink.gif). You should def start a thread introducing yourself to this gang... |
930cabman main bearings Nov 27 2021, 09:55 AM
914Sixer You have to remember that your old bearing shell h... Nov 27 2021, 01:37 PM
930cabman
You have to remember that your old bearing shell ... Nov 27 2021, 04:31 PM
914Sixer Yes the old bearing remains crushed. Yes you can ... Nov 27 2021, 07:14 PM
Mark Henry Yes the bearings is a torqued spec. Plastigauge is... Nov 28 2021, 01:06 PM
930cabman Crushed!!
I may have known this in the pa... Nov 30 2021, 11:26 AM
930cabman Yes, as expected: I did assemble the crank/new mai... Nov 30 2021, 06:54 PM
930cabman Yes, as expected: I did assemble the crank/new mai... Nov 30 2021, 06:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th October 2026 - 09:47 AM |
