| Fanmac |
Nov 23 2021, 12:00 PM
Newbie ![]() Group: Members Posts: 5 Joined: 23-November 21 From: SC Member No.: 26,102 Region Association: None |
Hello,
Please listen to the attached video and tell me what you think. It sounds like top end valve train noise, push rod? See links below, I appreciate your time. 914 1974 1.8 stock https://youtu.be/FjfgbFgZY64 Thanks. |
| Fanmac |
Dec 1 2021, 10:45 AM
Well, we checked everything listed above and still no solution. At this point, we're going to take to see a VW specialist. Thanks everyone.
Fanmac Engine Noise: Stumped! Nov 23 2021, 12:00 PM
Shivers :confused:
Nov 23 2021, 12:19 PM
Fanmac It's fixed, please try again. Nov 23 2021, 01:09 PM
Shivers I'm hearing a lot of noises, but one sounds fr... Nov 23 2021, 02:21 PM
Robarabian Something in the fan shroud... blowing around.. I ... Nov 23 2021, 02:44 PM
Van B The engine sounds too smooth and steady for it to ... Nov 23 2021, 05:40 PM
wonkipop
The engine sounds too smooth and steady for it to... Nov 23 2021, 06:21 PM
wonkipop ah no i see its #4.
still it seems like maybe its ... Nov 23 2021, 06:35 PM
Van B That’s a good theory about the cooling flap Wonk... Nov 23 2021, 09:42 PM
914sgofast2 The proverbial lost 10mm socket kicking around in ... Nov 23 2021, 10:24 PM
930cabman
The proverbial lost 10mm socket kicking around in... Nov 24 2021, 06:02 AM
Fanmac Wow!! Thanks for all the replies. I'm ... Nov 24 2021, 07:20 AM
bretth Mouse carcass flopping around in air ducts? Nov 24 2021, 12:18 AM
iankarr @wonkinpop. You should be a doctor with those diag... Nov 24 2021, 09:32 AM
Fanmac Ok, removed the tinware and got into the shroud. F... Nov 24 2021, 10:00 AM
rjames Maybe remove the valve cover and check for a broke... Nov 24 2021, 11:27 AM
wonkipop
Maybe remove the valve cover and check for a brok... Nov 24 2021, 02:10 PM
Wew +me on the push rod to rocker spacing. too loose.... Nov 24 2021, 02:38 PM
rfinegan Sounds like an exhaust noise to me...look for leak... Dec 1 2021, 11:22 AM
rgalla9146 Run the engine with the alternator belt off...see ... Dec 1 2021, 11:35 AM
wonkipop :(
when you find out report back.
interested 1.8... Dec 2 2021, 03:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:12 PM |
