> Engine Noise: Stumped!
Fanmac
post Nov 23 2021, 12:00 PM
Hello,
Please listen to the attached video and tell me what you think. It sounds like top end valve train noise, push rod? See links below, I appreciate your time.
914
1974
1.8 stock
https://youtu.be/FjfgbFgZY64
Thanks.
rgalla9146
post Dec 1 2021, 11:35 AM
Run the engine with the alternator belt off...see if it changes or stops.
I once had a big flap on a belt making a similar noise.
Fanmac   Engine Noise: Stumped!   Nov 23 2021, 12:00 PM
Shivers   :confused:   Nov 23 2021, 12:19 PM
Fanmac   It's fixed, please try again.   Nov 23 2021, 01:09 PM
Shivers   I'm hearing a lot of noises, but one sounds fr...   Nov 23 2021, 02:21 PM
Robarabian   Something in the fan shroud... blowing around.. I ...   Nov 23 2021, 02:44 PM
Van B   The engine sounds too smooth and steady for it to ...   Nov 23 2021, 05:40 PM
wonkipop   The engine sounds too smooth and steady for it to...   Nov 23 2021, 06:21 PM
wonkipop   ah no i see its #4. still it seems like maybe its ...   Nov 23 2021, 06:35 PM
Van B   That’s a good theory about the cooling flap Wonk...   Nov 23 2021, 09:42 PM
914sgofast2   The proverbial lost 10mm socket kicking around in ...   Nov 23 2021, 10:24 PM
930cabman   The proverbial lost 10mm socket kicking around in...   Nov 24 2021, 06:02 AM
Fanmac   Wow!! Thanks for all the replies. I'm ...   Nov 24 2021, 07:20 AM
bretth   Mouse carcass flopping around in air ducts?   Nov 24 2021, 12:18 AM
iankarr   @wonkinpop. You should be a doctor with those diag...   Nov 24 2021, 09:32 AM
Fanmac   Ok, removed the tinware and got into the shroud. F...   Nov 24 2021, 10:00 AM
rjames   Maybe remove the valve cover and check for a broke...   Nov 24 2021, 11:27 AM
wonkipop   Maybe remove the valve cover and check for a brok...   Nov 24 2021, 02:10 PM
Wew   +me on the push rod to rocker spacing. too loose....   Nov 24 2021, 02:38 PM
Fanmac   Well, we checked everything listed above and still...   Dec 1 2021, 10:45 AM
rfinegan   Sounds like an exhaust noise to me...look for leak...   Dec 1 2021, 11:22 AM
rgalla9146   Run the engine with the alternator belt off...see ...   Dec 1 2021, 11:35 AM
wonkipop   :( when you find out report back. interested 1.8...   Dec 2 2021, 03:16 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:12 PM
