| NARP74 |
Nov 30 2021, 12:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,574 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
My car had been wrecked in the past and had a new front end grafted on. Probably during its race years. When they put the new front end on, it did not have any ground studs where the headlights are.
As a fix, they just used a sheet metal screws for the ground and put it through the fender well. As a result, a couple ground wires are just floating in air not connected because they can not reach the sheet metal screw. I want to hook them up as they should be. Is there an early v late version of the ground studs and location? |
| NARP74 |
Dec 14 2021, 11:59 AM
Found this from Bowlsby, don't know if it is year dependent. It does show what is connected in the front ground stud locations. I should be able to figure out what is not connected and get it hooked up.
https://bowlsby.net/914/Classic/zTN_Elect_GroundPoints.jpg |
NARP74 Ground Studs Nov 30 2021, 12:16 PM
VaccaRabite There isn't a ground stud in the nose of the c... Nov 30 2021, 02:26 PM
NARP74
There isn't a ground stud in the nose of the ... Nov 30 2021, 05:50 PM
NARP74 This dropped fast. Anyone else? Dec 1 2021, 11:50 AM
Olympic 914 My '73 has Ground studs in the same place as p... Dec 1 2021, 03:18 PM
NARP74 It's strange but my grafted on front end did n... Dec 1 2021, 03:26 PM
914e Are you looking for these ground tabs? this is a 7... Dec 2 2021, 02:47 PM
NARP74 I guess I will just drill a hole and use a suitabl... Dec 3 2021, 12:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 02:45 AM |
