| Villemi |
Dec 20 2021, 01:57 PM
Newbie ![]() Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France |
Hello
I have december 75 2.0l Porsche 94 My car is an US one and had a canister and air pump. For late 74 diagram it was this one (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640074350.1.jpg) I don't have any more the canister and the air pump My car has no anti flash back valve too. Are you agree with the new diagram for my late 75 car ? (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640039023.1.jpg) It's difficult to understand when you have a 46years old !!! |
| BeatNavy |
Dec 21 2021, 06:04 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0
Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? |
| Villemi |
Dec 21 2021, 07:03 AM
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0 psi/bar at wide open throttle to somewhere over 22 psi / 1.5 bar during overrun (downshifting). Vacuum pull significantly higher may damage or blow the diaphragm inside the MPS. The decel valve opens up to relieve the vacuum. You can adjust the level at which the decel valve opens. I can't recall where a stock decel valve is set to open -- maybe 20 psi? Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? Yes thank you, And for the fashback valve ? Mandatory ? I don't understand where the hoses ar connected on the engine Pics possible ? |
| DRPHIL914 |
Dec 21 2021, 08:36 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
The decel valve is not mandatory -- some people remove them, but it does help prevent the MPS diaphragm from blowing on hard overrun (very high manifold vacuum). The MPS under 'normal' driving conditions can have manifold vacuum anywhere from 0 psi/bar at wide open throttle to somewhere over 22 psi / 1.5 bar during overrun (downshifting). Vacuum pull significantly higher may damage or blow the diaphragm inside the MPS. The decel valve opens up to relieve the vacuum. You can adjust the level at which the decel valve opens. I can't recall where a stock decel valve is set to open -- maybe 20 psi? Some people remove them completely as it brings RPM back to idle levels quickly and can enable faster shifting (e.g., for racing). If the devel valve is improperly adjusted you can get some strange behavior on shifting. Specifically, the idle RPM may hang too high for too long or drop too low or the engine may completely cut out. Does that help, Villemi? Yes thank you, And for the fashback valve ? Mandatory ? I don't understand where the hoses ar connected on the engine Pics possible ? @Villemi in 1975-1976 the factory did not put head vents on these cars and therefore no antiflash back valve, futhermore if you look at the research on this by LN engineering, Len Hoffman and Jake Raby did they found it better NOT to vent the heads( i just found this out last week and read thru all their research and documentation they did) - so you can follow the diagrams but if your heads are US heads with no vent then you will not hook up the anti-flash back valve. ALSO 75-76 US cars did not have a PVC the factory deleted it. I would not use a PVC , the stack at the oil filler is different, but what i would do and oh i did do is i connected the crank case vent hose to a catch can and that to the air cleaner. That will keep the oil vaper out of your air filter like Jeff said. If you put the hose to the manifold like the early cars had you are going to have what will amount to a high idle due to pulling too much air , just like a vac leak. - so - late cars had no PVC no head vents and no flash back valve. Phil |
Villemi Vacuum hoses for a late 75 2.0l Porsche 914 Dec 20 2021, 01:57 PM
rjames You’re missing the decel valve. Isn’t necessar... Dec 20 2021, 02:58 PM
Villemi
You’re missing the decel valve. Isn’t necessa... Dec 20 2021, 04:45 PM
JeffBowlsby Please take my name off your modified diagram and ... Dec 20 2021, 03:15 PM
Villemi Hello Jeff,
Excuse me for using your diagram
I... Dec 20 2021, 04:26 PM
JeffBowlsby
Hello Jeff,
I... Dec 20 2021, 06:48 PM
Villemi
Hello Jeff,
... Dec 21 2021, 02:19 AM
TX914 I have a 76 and I'm in agreement with @DRPHIL... Dec 21 2021, 09:01 AM
DRPHIL914
I have a 76 and I'm in agreement with [b]@[u... Dec 21 2021, 09:37 AM
StarBear
The decel valve is not mandatory -- some people r... Dec 21 2021, 07:54 AM
BeatNavy
[quote name='BeatNavy' post='2968551' date='Dec 2... Dec 21 2021, 08:04 AM
BeatNavy Flashback valve is another item that's not ... Dec 21 2021, 07:17 AM
BeatNavy Phil is correct. Something else I didn't key ... Dec 21 2021, 09:52 AM
StarBear
Phil is correct. Something else I didn't key... Dec 21 2021, 11:01 AM
Villemi After this discuss do you validate my diagram ?
O... Dec 21 2021, 04:25 PM
Bleyseng That looks correct but you will have to plug the 1... Dec 21 2021, 04:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:09 PM |
