Returning Barn Find BB To The Road |
DBF |
Jan 3 2022, 08:00 PM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I posted earlier about finding this survivor BB and I am working to get it back on the road by spring. I was asked to post more photos, and I’d also appreciate some advice on a couple items.
The first regards the engine. The car has 100K miles, and my experience with VW Type 1 motors is they are ready for a rebuild, at least a top-end rebuild at 100K. Is that true for Type 4's as well? I have the engine stripped down to the bare case/cylinders/heads since I want to clean off 100K worth of old oil/dirt, replace all the oil seals (yes all leaked), and to replace the fuel injection/air intake seals and vacuum lines to help ensure good drivability. Does the mileage say it’s time to keep taking it apart? The second regards the fuel pump. It is still in the rear of course, but I plan to pull the gas tank to replace the old fuel lines, including installing stainless steel lines. “While I’m at it”, should I move the fuel pump to the front? It changes the originality of the car, but I plan to autocross and attend DE events with the car, so looking for safety and reliability. Here is the car on the lift a friend gave me when he closed his auto repair shop this fall. It is a tight fit, but works for my small cars and old jeeps. I was sweating as the lift was being installed, hoping that all my calculations were correct, and was relieved when the 914 fit as planned. I was so anxious to see if it would fit that we lifted the 914 before we cleaned up the garage after the install. It will also allow me to store two small cars. Lastly, while on the lift I can still open and close the 914’s doors with one finger. |
DBF |
Jan 9 2022, 04:00 PM
Thanks for the concerns about my garage. I'm within code requirements. There is only one common wall between the house and garage, and they don't share a common attic. We have two 1/2 fire rated drywall between the house and garage. I also have an emergency cable stop for the lift, and it is attached to the pump motor right next to the button that raises the lift so can also be used as an emergency stop if the button sticks.
I was inspired by Cracker's photos of the original owner of his 68 911. Here's me with my '66 VW in 1974, and with the 914 when I picked it up. I think the 914 has weathered the years better than me! |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:55 AM |
