> Injector flow test FAIL ?, Troubleshooting lean condition
jim-c
post Jan 9 2022, 07:32 PM
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable.
I have an AFR gauge and it shows dead lean when i try to rev.
I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP .
Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish.
Any ideas ?
Nice new harness, MPS holds vacuum and has correct impedance readings.
The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds .
emerygt350
post Jan 10 2022, 05:56 AM
Since you have a 123 and the MPS really can be out of whack and the engine will still run "ok", I think you should a) check your timing (just to be sure) b) check to see that all injectors are firing c) disconnect the throttle switch to see if anything changes d) start to suspect the computer?
Any chance you didn't connect the trigger point wires correctly to the 123?
jim-c
post Jan 10 2022, 10:51 AM
QUOTE(emerygt350 @ Jan 10 2022, 06:56 AM) *
I just checked the timing with a light. Got 27 total at 3500 rpm.
I installed a second unmolested MPS and it runs the same. It starts good, idles decent, won't rev unless I spray gas down the TB opening.
I double checked the distributor to trigger point harness. Matches the instructions. Usin the two outside terminals with yellow on left side looking into connector.
I disconnected the throttle switch with and there's an improvement . I'm now able to get some revs and hold it at med or high rpm. The throttle switch looks new and I adjusted it with the ohm meter. Should I remove it and take a look inside ?
rjames
post Jan 10 2022, 11:39 AM
I'm made of metal
QUOTE(jim-c @ Jan 10 2022, 08:51 AM) *
Take off the cover and see if the tracks are worn. You might be able to clean them up with an eraser, or bend the arms just slightly so that they are making a better connection. If beyond repair, vendor(s) sell a replacement circuit board.
jim-c   Injector flow test FAIL ?   Jan 9 2022, 07:32 PM
JeffBowlsby   Do you mean resistance, or inductance? Has the MP...   Jan 9 2022, 09:37 PM
jim-c   Do you mean resistance, or inductance? Has the M...   Jan 9 2022, 09:52 PM
JeffBowlsby   Too many variables here now. An adjusted MPS, new...   Jan 9 2022, 11:45 PM
emerygt350   Since you have a 123 and the MPS really can be out...   Jan 10 2022, 05:56 AM
jim-c   Since you have a 123 and the MPS really can be ou...   Jan 10 2022, 10:51 AM
rjames   Since you have a 123 and the MPS really can be o...   Jan 10 2022, 11:39 AM
jim-c   Thanks for the replies. I flow tested all 4 inje...   Jan 10 2022, 09:21 AM
emerygt350   It's a super easy rebuild. I think I got mine...   Jan 10 2022, 12:00 PM
emerygt350   It's a super easy rebuild. I think I got min...   Jan 10 2022, 12:03 PM
JeffBowlsby   I am struggling to understand the low fuel flow an...   Jan 10 2022, 12:07 PM
jim-c   I am struggling to understand the low fuel flow a...   Jan 10 2022, 12:36 PM
rhodyguy   The fuel sock lives in the bottom of the tank. If ...   Jan 10 2022, 12:45 PM
rjames   The fuel sock lives in the bottom of the tank. If...   Jan 10 2022, 12:54 PM
jim-c   The fuel sock lives in the bottom of the tank. If...   Jan 11 2022, 10:55 AM
914Mels   Im working on my recent 914 purchase. 2.0L engine...   Jan 10 2022, 01:31 PM
jim-c   Is the manifold pressure sensor hose clear? Are yo...   Jan 11 2022, 10:57 AM
jim-c   Progress update . Tank sock filter was vertical. ...   Jan 14 2022, 11:42 AM
emerygt350   Progress update . Tank sock filter was vertical....   Jan 14 2022, 01:35 PM
914sgofast2   Low idle vacuum is likely a timing problem or undi...   Jan 14 2022, 08:03 PM
emerygt350   Low idle vacuum is likely a timing problem or und...   Jan 14 2022, 08:42 PM
jim-c   Here’s an update /solution for my problem. I pul...   Jan 16 2022, 05:54 PM
StarBear   Here’s an update /solution for my problem. I pu...   Jan 16 2022, 06:01 PM
emerygt350   That is great. Post the link for the tester!   Jan 16 2022, 06:22 PM
- Lo-Fi Version Time is now: 29th September 2026 - 12:19 AM
