| jim-c |
Jan 9 2022, 07:32 PM
Newbie ![]() Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable.
I have an AFR gauge and it shows dead lean when i try to rev. I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP . Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish. Any ideas ? Nice new harness, MPS holds vacuum and has correct impedance readings. The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds . |
| rhodyguy |
Jan 10 2022, 12:45 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The fuel sock lives in the bottom of the tank. If not fully fouled, as demand increases delivery decreases. It will suck flat. With a drained tank you can look down the fill opening with a flashlight to see it's condition. The sock should be standing up. Not flattened and laying down. Pumping the tank empty is easy with facet pump, some lengths of fuel line, a battery and a catch container. A BIG catch container.
| jim-c |
Jan 11 2022, 10:55 AM
The fuel sock lives in the bottom of the tank. If not fully fouled, as demand increases delivery decreases. It will suck flat. With a drained tank you can look down the fill opening with a flashlight to see it's condition. The sock should be standing up. Not flattened and laying down. Pumping the tank empty is easy with facet pump, some lengths of fuel line, a battery and a catch container. A BIG catch container. Thanks. I will do this today. |
jim-c Injector flow test FAIL ? Jan 9 2022, 07:32 PM
JeffBowlsby Do you mean resistance, or inductance? Has the MP... Jan 9 2022, 09:37 PM
jim-c
Do you mean resistance, or inductance? Has the M... Jan 9 2022, 09:52 PM
JeffBowlsby Too many variables here now. An adjusted MPS, new... Jan 9 2022, 11:45 PM
emerygt350 Since you have a 123 and the MPS really can be out... Jan 10 2022, 05:56 AM
jim-c
Since you have a 123 and the MPS really can be ou... Jan 10 2022, 10:51 AM
rjames
Since you have a 123 and the MPS really can be o... Jan 10 2022, 11:39 AM
jim-c Thanks for the replies.
I flow tested all 4 inje... Jan 10 2022, 09:21 AM
emerygt350 It's a super easy rebuild. I think I got mine... Jan 10 2022, 12:00 PM
emerygt350
It's a super easy rebuild. I think I got min... Jan 10 2022, 12:03 PM
JeffBowlsby I am struggling to understand the low fuel flow an... Jan 10 2022, 12:07 PM
jim-c
I am struggling to understand the low fuel flow a... Jan 10 2022, 12:36 PM
rjames
The fuel sock lives in the bottom of the tank. If... Jan 10 2022, 12:54 PM
914Mels
Im working on my recent 914 purchase. 2.0L engine... Jan 10 2022, 01:31 PM
jim-c Is the manifold pressure sensor hose clear? Are yo... Jan 11 2022, 10:57 AM
jim-c Progress update .
Tank sock filter was vertical. ... Jan 14 2022, 11:42 AM
emerygt350
Progress update .
Tank sock filter was vertical.... Jan 14 2022, 01:35 PM
914sgofast2 Low idle vacuum is likely a timing problem or undi... Jan 14 2022, 08:03 PM
emerygt350
Low idle vacuum is likely a timing problem or und... Jan 14 2022, 08:42 PM
jim-c Here’s an update /solution for my problem. I pul... Jan 16 2022, 05:54 PM
StarBear
Here’s an update /solution for my problem. I pu... Jan 16 2022, 06:01 PM
emerygt350 That is great. Post the link for the tester! Jan 16 2022, 06:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th September 2026 - 12:20 AM |
