> Continuity Test Results, Help to interpret Continuity Test Results
MFejsa
post Jan 14 2022, 05:37 AM
Need help to interpret results of continuity test results (see attached) and explain what to do next to get my car running right.
Porsche 914 2.0L 1974 (I believe was originally a 1.7L)
My car starts, runs and drives but idles rough and wont rev past 4,000rpm. It hesitates on acceleration. I have changed virtually all components / parts from rebuilt MPS, tested TPS and works, ignition switch, fuel pump, air & cylinder head temp sensor, swapped out ECU to one that was tested to work, and the list goes on.
I am posting my continuity test results with the hope that some may have experienced or had the same results and knows what to look into more deeply or can diagnose.
The test results concluded the following:
1. When testing the ECU power source from main power relay I could not get the 1V voltage difference from the voltage measured at the battery terminal. No difference and remained the same. Voltage at the battery was 12.79 throughout
2. when testing the voltage at start signal from ignition switch the voltage dropped to 9.7V and was not greater than 12V. However, should be greater than 12V.
So, can anyone help, please. I haven't been able to get the car run and drive right since being restored and have run out of options.
Regards
Michael
emerygt350
post Jan 14 2022, 09:16 AM
The throttle body attachments were just to make sure you had the retard and advance going to the right port, but obviously that isn't an issue with the 123.
Sounds like you have everything covered, so this should be doable. I would verify you have the right injectors first, easy and free.
What is your vacuum at idle? Since everything else sounds good and you are having idle and rev issues I might be inclined to look at your valve adjustment.
emerygt350
post Jan 14 2022, 09:18 AM
QUOTE(emerygt350 @ Jan 14 2022, 10:16 AM) *
Although I guess you could still have the vacuum line going to the wrong port if you are running advance on your 123 and it is a 74. Some 74s have both vacuum and advance ports on the Throttle body. Make sure yours is hooked to the port closest to the distributor if you are doing advance. Is this a bluetooth 123 or the pot one?
MFejsa
post Jan 14 2022, 10:25 AM
Mine is not a bluetooth version so must be a POT one. The throttle body on the engine only has the one port and ive connected the vacuum line to that port which is located at the rear of the throttle body (towards the rear of the car). Is it possible that I've hooked up the 123iginition to the retard? (there is no port closest to the distributor).
rjames
post Jan 14 2022, 10:30 AM
I'm made of metal
QUOTE(MFejsa @ Jan 14 2022, 08:25 AM) *
Yes- the port on your TB is retard, not advance.
MFejsa
post Jan 14 2022, 10:56 AM
Thanks. Will take another look at the hoses.
MFejsa   Continuity Test Results   Jan 14 2022, 05:37 AM
emerygt350   I put a new solid state regulator in mine recently...   Jan 14 2022, 05:51 AM
MFejsa   Thanks for the response. See below my responses. ...   Jan 14 2022, 06:26 AM
ejm   1. When testing the ECU power source from main po...   Jan 14 2022, 06:10 AM
MFejsa   Appreciate the response. See below my response. Y...   Jan 14 2022, 06:37 AM
jim-c   I feel your pain. I'm in the same boat. I have...   Jan 14 2022, 08:06 AM
emerygt350   The throttle body attachments were just to make su...   Jan 14 2022, 09:16 AM
emerygt350   The throttle body attachments were just to make s...   Jan 14 2022, 09:18 AM
MFejsa   Mine is not a bluetooth version so must be a POT o...   Jan 14 2022, 10:25 AM
rjames   Mine is not a bluetooth version so must be a POT ...   Jan 14 2022, 10:30 AM
MFejsa   Thanks. Will take another look at the hoses.   Jan 14 2022, 10:56 AM
JeffBowlsby   Sounds like an ignition timing/advance issue.   Jan 14 2022, 09:33 AM
emerygt350   I agree with Jeff. And now I notice that you thin...   Jan 14 2022, 09:44 AM
Van B   Wait, are we gonna talk about that 9.7v? What was ...   Jan 14 2022, 09:59 AM
MFejsa   Im getting more that 12v at the battery but 9.7V a...   Jan 14 2022, 10:26 AM
Van B   Im getting more that 12v at the battery but 9.7V ...   Jan 14 2022, 11:00 AM
MFejsa   Hi, thanks for the message. Check all grounds man...   Jan 14 2022, 12:56 PM
Van B   Hi, thanks for the message. Check all grounds ma...   Jan 14 2022, 04:48 PM
914Mels   Im getting more that 12v at the battery but 9.7V ...   Jan 14 2022, 11:16 AM
MFejsa   Thanks for the advice. I pulled the relay board f...   Jan 14 2022, 12:49 PM
emerygt350   Just out of curiosity, did you just disconnect the...   Jan 14 2022, 01:38 PM
MFejsa   I tried without the vacuum attached on the advance...   Jan 15 2022, 02:29 AM
Dustin   are you sure its running on all 4   Jan 14 2022, 05:21 PM
emerygt350   are you sure its running on all 4 Funny thing is...   Jan 14 2022, 08:55 PM
Superhawk996   Joining this thread late but I don't see any v...   Jan 15 2022, 12:02 PM
MFejsa   ECU - ive also changes the ECU to another which wa...   Jan 15 2022, 03:30 PM
- Lo-Fi Version Time is now: 26th November 2026 - 05:41 AM
