| worn |
Jan 14 2022, 07:45 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,648 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Hi Folks,
The welding of my 2056 car is drawing to a close and I think of priming and painting. Normally I use a PPG epoxy like DP40. Right now I have some epoxy primer from Eastwood on hand. I plan to paint the car in the original silver, so I hope to use PPG DBC base coat under a PPG clear. Can I use the Eastwood product (that looks sort of like Kirker) underneath. The money is not my issue: it is trying not to be wasteful. Thanks. Stay safe and happy. |
| Can-Am |
Jan 14 2022, 10:32 PM
Newbie ![]() Group: Members Posts: 37 Joined: 20-November 07 From: Scottsdale, AZ Member No.: 8,360 Region Association: None
Spray the Eastwood epoxy to seal the bare metal. Let it cure for a couple of days, scuff sand it and spray some PPG filler primer over the top of it. I don't think that's a problem. If you're nervous do the 2" tape test. Stick the tape down with pressure and then pull it off fast as if it's going to hurt.
Once they took the lead out of DP epoxy it hasn't been my favorite. Tastes great and less filling. |
worn Epoxy primer Jan 14 2022, 07:45 PM
mepstein I was always told to stick to the same brand. Jan 14 2022, 07:48 PM
worn
Ma... Jan 14 2022, 08:29 PM
M... Jan 14 2022, 09:23 PM
IronHillRestorations Use the Eastwood on the secondary surfaces, trunks... Jan 14 2022, 09:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 05:15 AM |
