| Dion |
Jan 14 2022, 06:34 PM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,935 Joined: 16-September 04 From: Shepherdstown, WV Member No.: 2,766 Region Association: MidAtlantic Region
Hey Fellas , so I’m getting close to starting my 2.4L. I’ve read that the original 6 takes 9 quarts. Mine is slightly larger as stated. I want to start adding oil to the system. Not only to look for leaks but want to get some in the block so I can rotate her without fear of
scuffing up metal that shouldn’t. I know your supposed to check when hot and running. How much would you add at first. Any starting procedure tips. It is carbed and does NOT have a front cooler. Appreciate any insight and experience. Cheers, Dion Engine porn (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
| lesorubcheek |
Jan 14 2022, 08:42 PM
Member ![]() ![]() Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
Beautiful engine Dion, and a great question. Been pondering the same thing. So, what if you aren't using a factory tank, dipstick or filler neck..... does anyone know approximately the actual level in a tank that's considered full? Say relative to the lower edge of the filler opening or some other point on the tank. I'm gonna need to calibrate a dipstick. Thought about looking at the 911's tank and see where it's dipstick full level sits relative to it's filler and use that. Doesn't seem to be an exact science, just gotta not overfill and have oil burping out all over, and obviously have enough that it isn't sucking air, but it'd be nice to hear from those with experience.
Dan |
| mb911 |
Jan 15 2022, 07:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,832 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Beautiful engine Dion, and a great question. Been pondering the same thing. So, what if you aren't using a factory tank, dipstick or filler neck..... does anyone know approximately the actual level in a tank that's considered full? Say relative to the lower edge of the filler opening or some other point on the tank. I'm gonna need to calibrate a dipstick. Thought about looking at the 911's tank and see where it's dipstick full level sits relative to it's filler and use that. Doesn't seem to be an exact science, just gotta not overfill and have oil burping out all over, and obviously have enough that it isn't sucking air, but it'd be nice to hear from those with experience. Dan Dan, My tanks are larger.. again the proper procedure so everyone is on the same page and more detail then last response. Keep in mind I have sold 100s of tanks and have explained this thousands of times. 1. No external oil cooler fill tank with 9 qts. 2. Turn the engine over with now plugs or fuel until oil pressure 3. Start engine and get to 180 degrees on a flat level surface. 4. Mark the dipstick so you know the minimum level. 5. For my tanks and larger capacity oil lines add another 1qt max. 6 again follow steps 1 -4 to the tee don't vary and you will be golden. 7 don't ever trust dip stick level fill lines without following steps 1-4. |
| lesorubcheek |
Jan 15 2022, 12:59 PM
Dan, My tanks are larger.. again the proper procedure so everyone is on the same page and more detail then last response. Keep in mind I have sold 100s of tanks and have explained this thousands of times. Thanks Ben. Appreciate your explanation. Mark, you make alot of sense too. Thanks. Dion, on the topic of initial engine run, there's some interesting posts on pelican regarding first starts and break in. Most key in on whether the engine has new cams and/or new pistons/rings, or whether it's original components. Not sure of the details of your engine, so this may not matter for you. You may well be aware of this anyway, so please ignore if so. Most posts are consistent with what you hear regarding any type engine. New cams need constant rpm but not too fast, ensuring good oil pressure and a break in time of ~20 minutes. New rings need varying load for break in which is contrary to cam break in procedure. Most agree the make sure cams are treated nicely first, then drive it with varying load for ring seating. Another reference is the Dempsey book on rebuilding 911 engines. His book is assuming a complete rebuild. After the initials steps of cranking engine with plugs out to ensure oil pressure, and steps for getting fuel system ready, he says to start engine, bring to 2000 rpm and using a stop watch, run it for 20 minutes. Switch off and drain the oil. Refill with oil. For the first drive, take it out for 3 to 5 miles, varying rpm and keeping it under 5k. Drive it back home and check oil level. He doesn't say whether to let the engine cool or not, but think he intends to keep it warm, just make sure you check the oil level. Then take it for a second drive of 8 to 10 miles, driving the same as the first drive. Drain the oil again. He does specify to let the engine cool completely before driving again the following day. On the following day, check ignition timing and adjust carbs as needed, warm up by driving and then check oil level again. He recommends another oil change at 500 miles along with adjusting valve clearance, at least on magnesium case engines. Lots of opinions out there. Dempsey's seems hyper-conservative nth degree of perfection as opposed to just jump in and drive it and change the oil after it starts looking dark would kinda be on the other end. Dan |
Dion Oil capacity for 914-6 conversion Jan 14 2022, 06:34 PM
Luke M We put 10 qts in my brothers 3.0 6 conv with an or... Jan 14 2022, 06:50 PM
Cairo94507 I usually put about 9 quarts in my car and then ta... Jan 14 2022, 07:13 PM
mb911 9 qts. Start car and run until 180. Check oil leve... Jan 14 2022, 07:19 PM
rgalla9146 Hey Dion
From empty I'd put in eight qua... Jan 14 2022, 08:20 PM
IronHillRestorations
Hey Dion
From empty I'd put in eight qu... Jan 14 2022, 08:52 PM
worn I think this is a really good question for anyone ... Jan 14 2022, 08:56 PM
I think this is a really good question for anyone... Jan 14 2022, 09:46 PM
Dion Thanks guys for all the tips! Ok, will go with... Jan 14 2022, 09:57 PM
roblav1 If carbs sat 3 years, you might want to check the ... Jan 14 2022, 10:37 PM
Dion @roblav1 , Nice! That’s perfectly spelled ... Jan 14 2022, 11:00 PM
Mark Henry I fill the tank till I can see oil on the dipstick... Jan 15 2022, 08:55 AM
mb911
I fill the tank till I can see oil on the dipstic... Jan 15 2022, 11:57 AM
Dion @lesorubcheek Dan, thanks for the info. Engine ... Jan 15 2022, 03:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 02:24 PM |
