Early versus late 1974 |
Lockwodo |
Jan 19 2022, 07:47 PM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
Would anyone happen to know what the breakpoint in VIN #s is for "early" 1974 versus "late" 1974 914s?
JeffBowlsby |
Jan 19 2022, 08:44 PM
914 Wiring Harnesses Group: Members Posts: 8,526 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have owned both 'early and late' '74 2.0Ls.
Do not know of a definitive list of changes, nor the VIN inflection point which seems to be a progressive set of dates depending on the change, not a single date. The factory parts manual may indicate changes to spcific parts associated with a VIN. Some differences: -silver center gauges changed to black center gauges -charcoal canister relocated from fuel tank to engine bay rear wall -carpeting changed from solid colors to 'salt and pepper' patterns -a brief period of a few weeks in Spring of 74 when grey headlight relay covers were installed -fuel expansion chamber and fuel tank cap changed from metal to plastic Interestingly, the Can Am cars produced in the Spring of 74 include a range of these changes. Thats all I can think of right now. |
Lockwodo |
Jan 19 2022, 08:59 PM
Well, what started me wondering is that in the 914/4 Tech Notebook there are two vacuum hose diagrams applicable to the '74 2.0, attributed to Jeff Bowlsby. One is for "1973 thru early 1974" and the other is for "late 1974". Sounds like there isn't a VIN cutoff point, so I'll just compare both diagrams to what I've got and see which matches. It's probably the late 1974 diagram since I have the black center gauges and charcoal canister in the engine compartment.
Dave_Darling |
Jan 19 2022, 11:13 PM
It's probably the late 1974 diagram since I have the black center gauges and charcoal canister in the engine compartment. I think that the only difference in terms of hoses is that the earlier 74s have the charcoal canister up front, like the 70-73 cars do, while the later 74s have it in the engine bay like the 75+ cars do. My 10/73 build 2.0 has the front-mounted canister. My old 1.8, which I think was also built around 10/73 according to the door jamb tag, had the canister in the engine bay. --DD |
wonkipop |
Jan 20 2022, 03:36 AM
Advanced Member Group: Members Posts: 4,376 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
It's probably the late 1974 diagram since I have the black center gauges and charcoal canister in the engine compartment. I think that the only difference in terms of hoses is that the earlier 74s have the charcoal canister up front, like the 70-73 cars do, while the later 74s have it in the engine bay like the 75+ cars do. My 10/73 build 2.0 has the front-mounted canister. My old 1.8, which I think was also built around 10/73 according to the door jamb tag, had the canister in the engine bay. --DD we finished off what you started more than 10 years ago dave. between you and jeff - what you guys had down on the record together, the old how many hoses from distributor to throttle body - and why - was crackable. bit of head scratching and 50 years after it all went down in western germany, i think we got to the bottom of it,. i read a few of your comments on other sites and here from a decade ago and i commend your open minded-ness and reporting on what you saw on the objects themselves. (IMG:style_emoticons/default/beerchug.gif) |
Lockwodo |
Jan 20 2022, 08:35 AM
Thanks guys, this is all super helpful! I'm new to 914s and air cooled VW engines and appreciate the wealth of info and helpful pointers from this community.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:50 PM |
