fresh air fan bad resistor?, defrost fresh air |
Medtner3 |
Jan 21 2022, 10:52 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
update: well, the fan was working now not even that is working. I think I might have fried the motor when I was hooking up the leads to test the fan through the resistor prongs I accidentally let the pos and neg cross ... when it rains it pours not going well today
Edited: I took my fresh air box fan out of the car and tested with a 12 V battery and it spins and works. But the resistor does not seem to work: I put 12V positive lead on the upper right pole where power comes in ( I get 11.84 volts on this terminal when the ignition was on) . ... as I understand it the other three poles are ground for the three fan speeds? So I connect each one to ground and the fan does not work assuming I am testing correctly>>>> can you rebuild a resistor or perhaps clean it with contact cleaner and make it work again https://forums.pelicanparts.com/porsche-911...ower-motor.html https://forums.pelicanparts.com/porsche-914...roster-fan.html |
barefoot |
Jan 22 2022, 08:33 AM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I'd pull the assembly out & look at the seals on the movable doors, they're probably turned to mush. Mickey (914 rubber) sells the whole rebuild kit while you're in there.
Medtner3 |
Jan 22 2022, 09:20 AM
I'd pull the assembly out & look at the seals on the movable doors, they're probably turned to mush. Mickey (914 rubber) sells the whole rebuild kit while you're in there. I already rebuilt it. stupidly forgot to test the fan while it was off, though. I might have to pull it anyway because doesn't seem like the flaps are closing completely when the fan is in the off position |
Lo-Fi Version | Time is now: 10th June 2024 - 11:44 AM |
