Handling issues - need adjustment advice |
Brian Fuerbach |
Jan 20 2022, 02:57 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. Things get better with a full tank of fuel. Is that just the nature of the 914, full tank factored into weight bias, or can the suspension be tuned to emulate the weight.
Here is what Im working with; -19mm adjustable sway-bar set about 1” back from full soft. -Koni yellow adjustable shocks -Stock front torsions -Rear springs are aftermarket (reddish orange color) but I do not know the poundage. Any input would be appreciated. |
Superhawk996 |
Jan 24 2022, 06:40 PM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
So I did a quick rationality check tonight using the highly scientific bathroom scale and tape measure.
168 lbs at 1.75" travel = 96 lbs/in for the 914Rubber 100lb/in spring. Pretty close. quick design comparison using an online spring calculator https://www.thespringstore.com/spring-calculator.html Design #1 close to 914Rubber 9.6mm wire diameter 105.5mm OD 380 mm free length (15 inches) 6 effective coils Result 90.795 lb/in (sorry for mixed units -- Imperial units for ease of comparision) Design #2 close to published stock data and the chart data above 9.6mm wire diameter 105.5 mm OD 470mm free length (18.5 inches) 10 effective coils Result 54.477 lb/in Design #3 published data from factory manual 9.6mm wire diameter 95mm mean OD -- this works out about the same 105.5 mm OD I measured directly 460 mm free length (18.1 inches) 10 effective coils Result 54.477 lb/in (IMG:style_emoticons/default/idea.gif) So I was wrong assuming that the chart data seemed low at 50's ish lbs/in rate. That is super interesting since I've always been lead to believe that stock springs were in the 90-100 lb range. I guess I'm guilty of propagating mythology. Anyone have an OEM stock spring to confirm free length? Super interesting information that I should have verified for myself long ago! |
Brian Fuerbach |
Jan 24 2022, 07:56 PM
So I did a quick rationality check tonight using the highly scientific bathroom scale and tape measure. 168 lbs at 1.75" travel = 96 lbs/in for the 914Rubber 100lb/in spring. Pretty close. quick design comparison using an online spring calculator https://www.thespringstore.com/spring-calculator.html Design #1 close to 914Rubber 9.6mm wire diameter 105.5mm OD 380 mm free length (15 inches) 6 effective coils Result 90.795 lb/in (sorry for mixed units -- Imperial units for ease of comparision) Design #2 close to published stock data and the chart data above 9.6mm wire diameter 105.5 mm OD 470mm free length (18.5 inches) 10 effective coils Result 54.477 lb/in Design #3 published data from factory manual 9.6mm wire diameter 95mm mean OD -- this works out about the same 105.5 mm OD I measured directly 460 mm free length (18.1 inches) 10 effective coils Result 54.477 lb/in (IMG:style_emoticons/default/idea.gif) So I was wrong assuming that the chart data seemed low at 50's ish lbs/in rate. That is super interesting since I've always been lead to believe that stock springs were in the 90-100 lb range. I guess I'm guilty of propagating mythology. Anyone have an OEM stock spring to confirm free length? Super interesting information that I should have verified for myself long ago! Thanks for sharing your measurements. I am really interested to know what my springs are but not enough to to pull one out. So if the 914rubber springs are 9.6mm wire and 96lb and my springs are 10.4mm diameter, would the larger wire automatically translate to a higher pound rating? |
Superhawk996 |
Jan 24 2022, 08:30 PM
So if the 914rubber springs are 9.6mm wire and 96lb and my springs are 10.4mm diameter, would the larger wire automatically translate to a higher pound rating? Yes larger wire = higher rate but don't forget that you have coating thickness on the wire. I'd assume the powder coat on springs is at least 0.5 - 1.0 mm thick. If you can see the coils, count them and them if you're around 8 coils, I'd say you're probably running 100 lb/in springs Assuming you're around 100 lb/in spring rate, to take us back to your original understeer behavior that you don't like, your choices are add rear bar or increase rear spring rate to decrease steady state understeer assuming you stay with the 19mm front bar. I ran 140's back in the day but I also gave up a good bit of ride quality and back then my car was biased toward oversteer when running stock torsion bars in the front and no anti-roll bars, 185 tires. |
Lo-Fi Version | Time is now: 6th June 2024 - 03:06 PM |
