TRS63 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe ![]() ![]() |
Hello together,
I bought what was supposed top be a complete front sway bar for my 914. As the tank is out, that would be a great time to mount it! But what I have is pretty strange, with welded screws instead of welded nuts: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-24690-1643118779.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-24690-1643118780.2.jpg) Is it then supposed to be welded like that, or from the inside, or it just doesn't work on the 914? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-24690-1643118780.3.jpg) Thanks! Antoine |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Tack weld the inner plate in place once everything is set and installed correctly.
The fender well is thin sheet metal and if you don't hit all the hole centers in true position then the plate will oval out and the fender well will eventually tear. Lots of threads on this install. I'd do like was suggested.....tack weld nuts in place and forget the studs and welding the backing place in place. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:13 PM |
