si2t3m |
914 addict ![]() ![]() Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 ![]() |
Hi,
Well, as the topic mentions it, seeking info regarding the flipped G50 setup. If you have one, i'm seeking info about the angulation of the half shafts and how the trans is mounted to the 914 / height / protuding in the rear trunk (if so on your install)?. Thanks! |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,517 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
When I was looking at transmissions for my big six, I researched the G-50. To put it in a 914, you have to flip it. But the bolt pattern on the bell housing is not symmetrical. So you have to plug and redrill the bolt holes. Then you have to cut out the rear trunk floor to be able to get the engine up into the engine compartment with the transmission. The axle shafts also run at an extreme angle, and you have to devise a way to shift it.
That's why I went with a G86-21 from a Cayman. Same basic transmission,but it is already mid engined. You have to make a clutch to adapt it to an air cooled engine, but you can buy off the shelf axles that work with a 914, and it is cable shifted. And you don't have to hack out the floor of the rear trunk either. Clay |
si2t3m |
When I was looking at transmissions for my big six, I researched the G-50. To put it in a 914, you have to flip it. But the bolt pattern on the bell housing is not symmetrical. So you have to plug and redrill the bolt holes. Then you have to cut out the rear trunk floor to be able to get the engine up into the engine compartment with the transmission. The axle shafts also run at an extreme angle, and you have to devise a way to shift it. That's why I went with a G86-21 from a Cayman. Same basic transmission,but it is already mid engined. You have to make a clutch to adapt it to an air cooled engine, but you can buy off the shelf axles that work with a 914, and it is cable shifted. And you don't have to hack out the floor of the rear trunk either. Clay Thanks Clay! I'm trying to catch up all I missed since selling my /6 (around 2010) and buying it back (fall 2020). I did read about the Boxster Caymen setup but still trying the bits & pieces to put it behind a 3.6 non varioram |
ClayPerrine |
When I was looking at transmissions for my big six, I researched the G-50. To put it in a 914, you have to flip it. But the bolt pattern on the bell housing is not symmetrical. So you have to plug and redrill the bolt holes. Then you have to cut out the rear trunk floor to be able to get the engine up into the engine compartment with the transmission. The axle shafts also run at an extreme angle, and you have to devise a way to shift it. That's why I went with a G86-21 from a Cayman. Same basic transmission,but it is already mid engined. You have to make a clutch to adapt it to an air cooled engine, but you can buy off the shelf axles that work with a 914, and it is cable shifted. And you don't have to hack out the floor of the rear trunk either. Clay Thanks Clay! I'm trying to catch up all I missed since selling my /6 (around 2010) and buying it back (fall 2020). I did read about the Boxster Caymen setup but still trying the bits & pieces to put it behind a 3.6 non varioram If it helps, this is my thread on putting a 964 engine into a 914 chassis with a Cayman 6 speed (G86-21) transmission. http://www.914world.com/bbs2/index.php?showtopic=279084 The goal was to put in the big 4.0L motor, and not have to modify the chassis. So I engineered it to work with the stock trans mounts. The only hole I had to cut was to run the DME wiring into the cabin. I am trying to make a clutch kit up for this to sell, but I have been delayed by Covid and my full time job. Let me know if you have any questions. Clay |
Lo-Fi Version | Time is now: 7th September 2025 - 10:23 AM |
