> Optimal front sway for a 1.7 ?
Literati914
post Feb 11 2022, 12:03 AM
I believe, if I’m not mistaken, there was a 13mm front sway bar for the 912 cars.. and I was wondering if that wouldn’t be more appropriate for a 1.7L 914 rather than the stock oem 15mm. I’m not sure if anyone bothers with a ARB on a 1.7L, but the 13mm ones are fairly easy to come by, cause everyone upgrades to bigger. So that’s a plus. Thoughts?
horizontally-opposed
post Feb 11 2022, 05:59 PM
Great discussion, and I've long wondered about adding a rear ARB.
Consensus when I added a front Weltmeister ARB and 140lb rear springs in the 1990s—hard won by a super active autocross and time trial community around the 914, presumably based on lap times + handling dynamics—seemed to be:
> Weltmeister front ARB, no rear ARB
> 140lb rear springs
> Konis (red for more street, yellow for more track)
> Lowered and aligned
> Widest rubber you can fit
I followed that recipe and also thought the car handled really well, both for autocross and for back roads. But this isn't 30 years ago, and I'm here to learn!
Literati914   Optimal front sway for a 1.7 ?   Feb 11 2022, 12:03 AM
wonkipop   I believe, if I’m not mistaken, there was a 13...   Feb 11 2022, 12:37 AM
914Sixer   Factory set it up for the best possible all round ...   Feb 11 2022, 06:59 AM
mepstein   The 13mm will be a lot better than no bar.   Feb 11 2022, 07:01 AM
Superhawk996   The 13mm will be a lot better than no bar. To t...   Feb 11 2022, 07:15 AM
Superhawk996   Anti roll bar size has nothing to do with engine s...   Feb 11 2022, 07:02 AM
914werke   Ive done at least one 13mm Front/No Rear update wi...   Feb 11 2022, 09:23 AM
mepstein   Ive done at least one 13mm Front/ No Rear update ...   Feb 11 2022, 10:22 AM
Superhawk996   Ive done at least one 13mm Front/ No Rear update...   Feb 11 2022, 11:31 AM
Superhawk996   I'm going to :stir: just a little more. The...   Feb 11 2022, 11:17 AM
Literati914   Anti roll bar size has nothing to do with engine ...   Feb 11 2022, 12:06 PM
Superhawk996   ... my mind a smaller bar would be more appropr...   Feb 11 2022, 01:17 PM
wonkipop   [quote name='Superhawk996' post='2981037' date='F...   Feb 11 2022, 06:16 PM
Superhawk996   note - they appeared to have the slightly stiffe...   Feb 11 2022, 06:37 PM
wonkipop   note - they appeared to have the slightly stiff...   Feb 11 2022, 08:17 PM
914_teener   [quote name='Superhawk996' post='2981153' date='F...   Feb 11 2022, 08:57 PM
mepstein   My 912 came with just the 13mm front bar. The 912/...   Feb 11 2022, 01:28 PM
Literati914   Wow, always a wealth of knowledge offered up so en...   Feb 11 2022, 02:47 PM
mepstein   Wow, always a wealth of knowledge offered up so e...   Feb 11 2022, 02:58 PM
emerygt350   Having a little roll and compression is a good thi...   Feb 11 2022, 05:29 PM
horizontally-opposed   Great discussion, and I've long wondered about...   Feb 11 2022, 05:59 PM
Superhawk996   I followed that recipe . . . The only real p...   Feb 11 2022, 06:31 PM
horizontally-opposed   [quote name='horizontally-opposed' post='298...   Feb 12 2022, 03:18 PM
Literati914   .. to clarify - far as i know its 15 front and 16...   Feb 11 2022, 06:39 PM
Superhawk996   And just a side note, while we’re on the subje...   Feb 11 2022, 07:17 PM
wonkipop   .. to clarify - far as i know its 15 front and 1...   Feb 11 2022, 08:19 PM
Literati914   .., that car drove like it was on rails......forg...   Feb 11 2022, 09:46 PM
flyer86d   We ran a 19mm front with a 16mm rear on our 71 1.7...   Feb 12 2022, 02:13 PM
jkb081   I do not feel it is a fair comparison between a 91...   Feb 12 2022, 05:24 PM
roblav1   I do not feel it is a fair comparison between a 9...   Feb 12 2022, 05:48 PM
roblav1   Pete, adding LSD will make the car push coming out...   Feb 12 2022, 05:40 PM
horizontally-opposed   Pete, adding LSD will make the car push coming ou...   Feb 12 2022, 06:32 PM
- Lo-Fi Version Time is now: 1st August 2025 - 03:48 PM
