> Testing relay boards...., Can you bench test a 914 relay board....???
second wind
post Feb 24 2022, 02:05 AM
Hello out there....my car has been dying after getting a good warm up but starts the next morning. The tell tale symptom is that the fuel pump does not run when the stall occurs and even after hours of cooling off it still does not start...but it does in the morning....???
So talk on the street is the relay board is too old to work properly.....the description of 914 LTD's improved and rebuilt relay boards matches the symptoms of my car perfectly so as soon as I scrap up the money I will buy one.....meanwhile I have two spare relay boards and one looks really good. Is there a way to bench test the relay board before I swap the boards ?? These cars sure keep you on your toes and a relay board with fresh soldered connections sure sounds appealing so Brad is holding one for me. So back to the swap out....I hate to go to the effort just to install another faulty board. Look forward and appreciate any and all comments and help....thank you very much!!!!
gg
Superhawk996
post Feb 24 2022, 07:46 AM
(IMG:style_emoticons/default/agree.gif) with a couple modifications:
There is nothing magical about the relay board. It is actually from the stone age. Just large copper traces inside a plastic housing that runs continuity from point to point.
1) As a former electronics technician it annoys me to no end to see all the forum threads about electrical troubleshooting where the proposed solutions are simply guess work and parts swapping (Note: not targeting @second wind - just a generalization) I've largely stopped trying to participate in those threads because people refuse to use a schematic and a Digital Multi Meter (DMM). I know it might take some time to learn how to read schematics and/or to use a DMM. The reality is that if you're going to play with 50 year old cars, you're going to have to learn sooner or later. Google & YouTube are your friend for learning how to read schematics and to use a DMM. Otherwise:
a)You're going to pay $$ to someone skilled enough to use a DMM, a schematic, and then to troubleshoot properly.
b)You're going to waste $$ on needless parts and parts swapping
c) You're going to pay some other "mechanic" to do the parts swapping and guessing for you which is the worst possible outcome both for time and $$.
2) These boards do have a lot of swagged connections within them as 914 LTD states on the website. However, swagging is a form of crimping that is more reliable than soldering per Auto Industry, Aerospace, and NASA white papers. Yes, it is possible that a swagged connection could be come loose, but it is less likely than one of the soldered connections within the relay board with a cold solder joint, and/or a stress cracked solder joint. Sure you can solder every swagged connector as belt and suspenders, but in reality you're more likely to have a bad solder connection due to a dirty board and/or improper fluxing over the swagged connection than a bad swagged connection itself. If acid core flux is used to do the soldering, you'll have a long term corrosion source on the board itself if the flux is not completely removed. NOTE: I'm not trying to tear down the 914 LTD relay board. I understand why he's offering this as a service as there are bad boards out there with corroded traces, traces screwed up form DAPO's shooting long regulator screw across traces creating shorts, bad potting, and even some with stressed solder joints and/or swagged connections due to corrosion or improper handling over time. I understand why the solder belt and suspenders approach holds appeal and it's not likely to hurt anything. Having de-potted a couple boards myself, his pricing is fair, so is @914sixers for restored boards. It takes a lot of labor to remove the potting, continuity check, redo these boards with new potting
If you really want to do the whole bench test routine, do as @914sixer suggests and simply test all connections for continuity at room temperature.
If you want to go the next level and really think heat cycling is your problem, warm the board in your oven to about 150F - 200F then test continuity again. If you have the board de-potted, you could also use a heat gun (carefully) at the specific swagged connections of interest.
Going back to point #1, you don't have to test all continuity across the whole board, just those traces that handle the fuel pump, the ignition coil, the tachometer (which is also connected to the coil), and the ECU feeds (if fuel injected),
In OP you don't mention if you've already ruled out the relay itself, and whether you've verified the integrity and power feeds to the components (coil, pump, ECU) itself both hot and cold. I'd do that before jumping to swapping relay boards.
second wind
post Feb 24 2022, 11:42 AM
QUOTE(Superhawk996 @ Feb 24 2022, 05:46 AM) *
Thank you Superhawk....I did some relay swapping and ended up putting all new 914 Rubber relays on the board. Not hearing the fuel pump go on when turning the key makes me want to rule out a bad fuel pump since it works fine when cold and the new relays make me think that is not the problem either. I would love to hear more about these 50 year old relay boards.....do they really go bad or not? And when they do go bad what is the usual culprit? Thank you all very much!
gg
second wind   Testing relay boards....   Feb 24 2022, 02:05 AM
914Sixer   Yes you can test the board with a multi meter. I ...   Feb 24 2022, 07:12 AM
Superhawk996   :agree: with a couple modifications: There is no...   Feb 24 2022, 07:46 AM
second wind   :agree: with a couple modifications: There is n...   Feb 24 2022, 11:42 AM
Superhawk996   Thank you Superhawk....I did some relay swappin...   Feb 24 2022, 12:19 PM
raynekat   :agree: with a couple modifications: There is n...   Feb 24 2022, 09:10 PM
lesorubcheek   Tracking down intermittent electrical problems ain...   Feb 24 2022, 12:45 PM
Superhawk996   Here you go un-potted board. This is posted as mir...   Feb 24 2022, 03:31 PM
Puebloswatcop   :agree: All of the above. Using a dDMM is not roc...   Feb 24 2022, 04:00 PM
Bartlett 914   A relay board has no electronics. It is a buss bar...   Feb 24 2022, 04:53 PM
johnhora   Check the wire harness at the fuel pump.... I have...   Feb 24 2022, 05:08 PM
JeffBowlsby   The word is 'swaged', not swagged. But I ...   Feb 24 2022, 06:34 PM
Superhawk996   The word is 'swaged', not swagged. But I...   Feb 24 2022, 08:43 PM
930cabman   I assume the riveted/buss bar connection fails fro...   Feb 24 2022, 06:46 PM
volksaddict   I appreciate this info! I have. a fuel pump po...   Feb 24 2022, 09:12 PM
second wind   I am so appreciative you guys!!!!...   Feb 24 2022, 11:54 PM
second wind   I am so appreciative you guys!!!...   Feb 26 2022, 12:54 AM
dirk2056   :agree: almost 100% of the electrical problems I f...   Feb 26 2022, 07:22 AM
Superhawk996   I am so appreciative you guys!!!...   Feb 26 2022, 08:33 AM
iankarr   :agree: It’s important to collect hard data on...   Feb 26 2022, 09:14 AM
Superhawk996   :rotfl: at Ian's perfect description of what h...   Feb 26 2022, 12:56 PM
Superhawk996   Let's go back one more step, to the basics. ...   Feb 26 2022, 01:06 PM
dr914@autoatlanta.com   Here is an old guy explaining the function https:...   Feb 26 2022, 01:16 PM
second wind   Here is an old guy explaining the function https...   Feb 26 2022, 04:54 PM
Superhawk996   At the end I thought you were going to show us h...   Feb 26 2022, 05:19 PM
second wind   Well guys...thank you again very much and I have a...   Feb 26 2022, 04:31 PM
Superhawk996   Well guys...thank you again very much and I have ...   Feb 26 2022, 05:43 PM
Superhawk996   OK -- so now about the S10. Sounds an awful like...   Feb 26 2022, 05:53 PM
- Lo-Fi Version Time is now: 1st July 2025 - 09:03 AM
