second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Hello out there....my car has been dying after getting a good warm up but starts the next morning. The tell tale symptom is that the fuel pump does not run when the stall occurs and even after hours of cooling off it still does not start...but it does in the morning....???
So talk on the street is the relay board is too old to work properly.....the description of 914 LTD's improved and rebuilt relay boards matches the symptoms of my car perfectly so as soon as I scrap up the money I will buy one.....meanwhile I have two spare relay boards and one looks really good. Is there a way to bench test the relay board before I swap the boards ?? These cars sure keep you on your toes and a relay board with fresh soldered connections sure sounds appealing so Brad is holding one for me. So back to the swap out....I hate to go to the effort just to install another faulty board. Look forward and appreciate any and all comments and help....thank you very much!!!! gg |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,555 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
(IMG:style_emoticons/default/agree.gif) All of the above. Using a dDMM is not rocket science and they really arent that expensive. On these cars a definatly needed tool. Iread all the hype about soldering all of these connections. After stripping the bottom of my board and checking and rechecking the points, from both the top and the bottom found all of the swaged joints to be fine.
Just take your time and check each cirquit one at a time. The problem is most likely not the board. Probably a bad relay or some other problem in the electrical system. |
Lo-Fi Version | Time is now: 1st July 2025 - 09:17 AM |
