> Testing relay boards...., Can you bench test a 914 relay board....???
second wind
post Feb 24 2022, 02:05 AM
Hello out there....my car has been dying after getting a good warm up but starts the next morning. The tell tale symptom is that the fuel pump does not run when the stall occurs and even after hours of cooling off it still does not start...but it does in the morning....???
So talk on the street is the relay board is too old to work properly.....the description of 914 LTD's improved and rebuilt relay boards matches the symptoms of my car perfectly so as soon as I scrap up the money I will buy one.....meanwhile I have two spare relay boards and one looks really good. Is there a way to bench test the relay board before I swap the boards ?? These cars sure keep you on your toes and a relay board with fresh soldered connections sure sounds appealing so Brad is holding one for me. So back to the swap out....I hate to go to the effort just to install another faulty board. Look forward and appreciate any and all comments and help....thank you very much!!!!
gg
Superhawk996
post Feb 26 2022, 01:06 PM
Let's go back one more step, to the basics.
Before we even start assuming that there are electrical problems, with the fuel pump (only) when it's hot and not running, and you can't hear the fuel pump, have you pulled a spark plug and verified that it is sparking when hot?
Engine needs three things to run
fuel, compression, spark.
(Let's assume for the moment that we can ignore hot compression)
If you just assume that it won't run when hot due to no fuel pump noise, and haven't verified that it will spark, you're potentially missing an important clue on how we might start troubleshooting this. That is to say, we need to know for sure, when it's hot and not running, can we ignore the ignition circuit and focus only on the fuel pump? If we can ignore ignition side, that makes the troubleshooting work even easier.
What's being done here is to half split the system to the fuel side (Part A), and the ignition side (Part B). If by chance both fuel pressure is missing (no pump noise - Part A is bad) and we have no spark (Part B is bad), then we start looking for what is the common denominator between BOTH A & B.
This is a very important starting point.
Hopefully, this is making sense. Logical, and methodical.
second wind   Testing relay boards....   Feb 24 2022, 02:05 AM
914Sixer   Yes you can test the board with a multi meter. I ...   Feb 24 2022, 07:12 AM
Superhawk996   :agree: with a couple modifications: There is no...   Feb 24 2022, 07:46 AM
second wind   :agree: with a couple modifications: There is n...   Feb 24 2022, 11:42 AM
Superhawk996   Thank you Superhawk....I did some relay swappin...   Feb 24 2022, 12:19 PM
raynekat   :agree: with a couple modifications: There is n...   Feb 24 2022, 09:10 PM
lesorubcheek   Tracking down intermittent electrical problems ain...   Feb 24 2022, 12:45 PM
Superhawk996   Here you go un-potted board. This is posted as mir...   Feb 24 2022, 03:31 PM
Puebloswatcop   :agree: All of the above. Using a dDMM is not roc...   Feb 24 2022, 04:00 PM
Bartlett 914   A relay board has no electronics. It is a buss bar...   Feb 24 2022, 04:53 PM
johnhora   Check the wire harness at the fuel pump.... I have...   Feb 24 2022, 05:08 PM
JeffBowlsby   The word is 'swaged', not swagged. But I ...   Feb 24 2022, 06:34 PM
Superhawk996   The word is 'swaged', not swagged. But I...   Feb 24 2022, 08:43 PM
930cabman   I assume the riveted/buss bar connection fails fro...   Feb 24 2022, 06:46 PM
volksaddict   I appreciate this info! I have. a fuel pump po...   Feb 24 2022, 09:12 PM
second wind   I am so appreciative you guys!!!!...   Feb 24 2022, 11:54 PM
second wind   I am so appreciative you guys!!!...   Feb 26 2022, 12:54 AM
dirk2056   :agree: almost 100% of the electrical problems I f...   Feb 26 2022, 07:22 AM
Superhawk996   I am so appreciative you guys!!!...   Feb 26 2022, 08:33 AM
iankarr   :agree: It’s important to collect hard data on...   Feb 26 2022, 09:14 AM
Superhawk996   :rotfl: at Ian's perfect description of what h...   Feb 26 2022, 12:56 PM
Superhawk996   Let's go back one more step, to the basics. ...   Feb 26 2022, 01:06 PM
dr914@autoatlanta.com   Here is an old guy explaining the function https:...   Feb 26 2022, 01:16 PM
second wind   Here is an old guy explaining the function https...   Feb 26 2022, 04:54 PM
Superhawk996   At the end I thought you were going to show us h...   Feb 26 2022, 05:19 PM
second wind   Well guys...thank you again very much and I have a...   Feb 26 2022, 04:31 PM
Superhawk996   Well guys...thank you again very much and I have ...   Feb 26 2022, 05:43 PM
Superhawk996   OK -- so now about the S10. Sounds an awful like...   Feb 26 2022, 05:53 PM
- Lo-Fi Version Time is now: 1st July 2025 - 02:10 PM
