> Red wire with some crispy insulation....
advman89
post Feb 28 2022, 09:09 PM
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address.
FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too...
There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational.
And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction.
I know I have a color wiring chart...off to the archives for it to start looking for things.
914sgofast2
post Feb 28 2022, 09:13 PM
You have my sympathy. I am trying to sort out the turn signal and hazard light wiring on my 1970. The wiring diagrams in the Haynes book are virtually worthless. That said, a red wire is usually a “hot” wire from somewhere; it’s never a ground wire. All ground wires are brown.
advman89   Red wire with some crispy insulation....   Feb 28 2022, 09:09 PM
914sgofast2   You have my sympathy. I am trying to sort out the ...   Feb 28 2022, 09:13 PM
VaccaRabite   Big red wire is either going from the ignition swi...   Feb 28 2022, 09:28 PM
Costa05   I'm in the depths of a full dash replacement ...   Feb 28 2022, 10:48 PM
barnfind9141972   What year is it? I have a 72-73 diagram that’s a...   Mar 1 2022, 03:46 AM
Spoke   About the blue/white wire shorted to the brown wir...   Mar 1 2022, 04:48 AM
Superhawk996   If you wanted to remove that wire from service, f...   Mar 1 2022, 07:25 AM
advman89   Thank you all for the replies. The Car is a 1971 ...   Mar 1 2022, 09:13 AM
advman89   Gotcha. Check this out! Opened the connect...   Mar 1 2022, 11:33 PM
Superhawk996   :trophy: Nice job getting that out of there. Hope...   Mar 2 2022, 06:57 AM
advman89   I checked all the adjacent wires and there are no ...   Mar 2 2022, 08:21 AM
Superhawk996   I checked all the adjacent wires and there are no...   Mar 2 2022, 08:48 AM
advman89   Here are some photos... PIN 12 (depending on diag...   Mar 2 2022, 12:27 PM
ejm   That power distribution junction block was only us...   Mar 2 2022, 05:44 PM
advman89   That power distribution junction block was only u...   Mar 3 2022, 09:56 AM
Costa05   I have a 73 and dont have that screw post conne...   Mar 2 2022, 05:59 PM
Superhawk996   I'm out of my league based on the photos becau...   Mar 2 2022, 02:01 PM
advman89   Mine is a 71. I don't know if there are a lot ...   Mar 2 2022, 03:55 PM
914sgofast2   Mine is a 71. I don't know if there are a lot...   Mar 2 2022, 05:54 PM
Superhawk996   is this a 914-6?   Mar 2 2022, 04:02 PM
barefoot   I had to install a complete replacement harness in...   Mar 3 2022, 07:39 AM
Costa05   I had to install a complete replacement harness i...   Mar 3 2022, 08:13 AM
johnorm   I had to install a complete replacement harness i...   Mar 23 2023, 11:43 AM
Superhawk996   I hate to admit this since I generally think the e...   Mar 3 2022, 08:48 AM
advman89   ...and now I'll be adding in fuseblock near th...   Mar 3 2022, 05:42 PM
anderssj   That power distribution block is there on my ...   Mar 3 2022, 07:43 PM
advman89   The ground block was removed last night, wires pro...   Mar 4 2022, 08:50 AM
advman89   Fuse block is in place. I feel better. Thank you a...   Mar 14 2022, 12:19 PM
VaccaRabite   Fuse block is in place. I feel better. Thank you ...   Mar 16 2022, 12:00 PM
ClayPerrine   Fuse block is in place. I feel better. Thank you...   Mar 16 2022, 02:26 PM
Geezer914   Did the Ford solenoid for the starter and 4 fuses ...   Mar 23 2023, 03:47 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:01 PM
