> Early vs Late 914-4 Front Brakes, aka CBPerformance 5 bolt discs?
tomeric914
post Feb 27 2022, 10:58 AM
One Lap of America in a 914!
edit: Scroll to post 15 here http://www.914world.com/bbs2/index.php?s=&...t&p=2985423
https://www.cbperformance.com/product-p/4182.htm
Somewhat expensive, but has anyone tried these on a 914?
Appears to have the same bearings as 914.
Might fit 70-71 914-4 but not sure about later years
tomeric914
post Mar 3 2022, 08:21 AM
Thanks to @Eric_Shea and everyone's input above, I think I may have the summary below correct.
Early is before August of 1972. Late is after August of 1972:
- All 914-4 spindles are the same and use the same bearings
- There is a difference in part number for the strut assembly but that is related to the ball joint attachment. Early had the pinch bolt, late had the tapered bolt
- Early 914 used a VW Type 1 rotor. Late 914 used a 411/412 rotor. Late rotors were thicker with more reinforcement in the hub to prevent flexing of the rotor while cornering.
- Relative to the spindle, the later rotors had a different offset. Therefore, later calipers had a different offset. The later caliper also had to accommodate the thicker rotor
Next step is to purchase either the CBPerformance rotors or another off the shelf T1 rotor already drilled for 5 bolt and report back!
ChrisFoley
post Mar 3 2022, 12:25 PM
I am Tangerine Racing
QUOTE(tomeric914 @ Mar 3 2022, 09:21 AM) *
When the rotor was changed, the caliper offset on the strut also changed. The knuckle castings are different between early and late struts.
tomeric914   Early vs Late 914-4 Front Brakes   Feb 27 2022, 10:58 AM
raynekat   The price looks reasonable to me. Other than that....   Feb 27 2022, 01:49 PM
Chris914n6   Slotted rotors just shave the pads so no way I wou...   Feb 27 2022, 02:33 PM
sportlicherFahrer   Early and late 914 rotors are from the 411 parts b...   Feb 28 2022, 09:42 AM
euro911   I would suspect that they're designed for Beet...   Feb 28 2022, 10:29 AM
sportlicherFahrer   Did more digging, and it looks like the center sec...   Feb 28 2022, 12:39 PM
tomeric914   Did more digging, and it looks like the center se...   Feb 28 2022, 04:33 PM
Chris914n6   Back in the day, the easy way was to use 911 fron...   Feb 28 2022, 05:21 PM
sportlicherFahrer   Nice! Where did you find the detailed info ...   Feb 28 2022, 07:07 PM
Literati914   The beetles, 411/412 have the same spindle dimensi...   Feb 28 2022, 09:15 PM
tomeric914   There have been a few cnc one-offs. Paging @[ur...   Feb 28 2022, 10:44 PM
Chris914n6   I think the 914 spindles are all the same. The dif...   Mar 1 2022, 02:32 AM
Literati914   The beetles, 411/412 have the same spindle dimen...   Mar 1 2022, 10:55 AM
djway   I took some VW rotors over to Bruce stones shop a ...   Mar 1 2022, 10:26 PM
Literati914   @djway Thanks for confirming & what was it e...   Mar 3 2022, 12:41 AM
tomeric914   Thanks to @[url=http://www.914world.com/bbs2/inde...   Mar 3 2022, 08:21 AM
ChrisFoley   - There is a difference in part number for the st...   Mar 3 2022, 12:25 PM
GregAmy   If you want to use late 914 calipers onto an early...   Mar 3 2022, 12:49 PM
djway   I considered the CB rotors and the Sabro rotors th...   Mar 3 2022, 02:20 PM
tomeric914   Now that I have the 914 in my shop, the plot thick...   Apr 29 2022, 10:37 AM
mepstein   In my opinion, it's so much easier to go with ...   Apr 29 2022, 11:21 AM
tomeric914   In my opinion, it's so much easier to go with...   Apr 29 2022, 06:41 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:28 PM
