> Piston ring end gap, AA 96 mm pistons with Grant rings
jsaum
post Mar 3 2022, 10:04 PM
The instructions say .003 to .004 per inch of cylinder diameter. Calculates out to .011” to .015”. What end gap should I use? Anyone used this combination?
Thanks,
Jsaum
930cabman
post Mar 5 2022, 09:21 AM
As far as I know, they are all cast iron rings and should have similar specs, BUT make sure you get it right or the rings can break. Have you called the factory? Grant
jsaum
post Mar 5 2022, 10:02 AM
QUOTE(930cabman @ Mar 5 2022, 07:21 AM) *
I have the Grant factory instructions which call for a range of .003 to .004 per inch of diameter of the piston. That’s between .011 to .015. I’ll give AA performance a call Monday and see if they can give a recommendation.
jsaum   Piston ring end gap   Mar 3 2022, 10:04 PM
914Mels   For stock piston rings in all the 4 cylinder engin...   Mar 3 2022, 10:43 PM
jsaum   For stock piston rings in all the 4 cylinder engi...   Mar 3 2022, 10:57 PM
914Mels   That's too tight. I'd shop around for a in...   Mar 4 2022, 12:06 AM
jsaum   That's too tight. I'd shop around for a i...   Mar 4 2022, 12:36 AM
Al Meredith   Check the internet, I was surprised to read the KB...   Mar 4 2022, 05:19 PM
jsaum   I’ve looked and found several different call out...   Mar 4 2022, 05:37 PM
930cabman   As far as I know, they are all cast iron rings and...   Mar 5 2022, 09:21 AM
jsaum   As far as I know, they are all cast iron rings an...   Mar 5 2022, 10:02 AM
jsaum   Here’s a picture of three different pistons, fro...   Mar 5 2022, 10:29 AM
jsaum   Ok, after a ton of google searches and watching a ...   Mar 5 2022, 12:34 PM
930cabman   Personally, I would favor over .015 than less than...   Mar 5 2022, 01:48 PM
jsaum   Personally, I would favor over .015 than less tha...   Mar 7 2022, 11:51 AM
Olympic 914   [quote name='930cabman' post='2985938' date='Mar ...   Mar 7 2022, 01:40 PM
mihai914   Give Mark Henry some time and he should chime in. ...   Mar 7 2022, 01:02 PM
jsaum   Give [b]@[url=http://www.914world.com/bbs2/index...   Mar 7 2022, 01:14 PM
rhodyguy   PM him.   Mar 7 2022, 01:25 PM
930cabman   @Olympic: thanks for sharing. The engineering behi...   Mar 7 2022, 02:59 PM
Mark Henry   .017" is good, if you're over a hair I wo...   Mar 8 2022, 11:02 AM
jsaum   .017" is good, if you're over a hair I w...   Mar 8 2022, 09:07 PM
- Lo-Fi Version Time is now: 12th July 2025 - 03:28 PM
