Did original relay boards have plastic melted near traces? |
DaveB |
Mar 5 2022, 08:05 PM
Member Group: Members Posts: 165 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
I'm removing the tar off the relay board. I'm finding areas which look like a soldering iron touched and melted the plastic. I don't know if this was used to tack down some of the traces or something else. One area looks like someone laid down a soldering tip.
Was this normal or something else? Thanks, DaveB |
Superhawk996 |
Mar 6 2022, 04:50 AM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Normal
It is heat staking used to hold the traces in place during assembly. Both boards I’ve cleaned had same heat staking in places on the board. If you look carefully you’ll see they melted top down toward the trace. If the trace had overheated they would be melted at the base where the trace sits. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:48 PM |
