william1764 |
Member ![]() ![]() Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region ![]() |
Just had completed a full engine rebuild of my stock 2.0L (with Webers) to a 2.3L by a small Porsche indy in Maryland (2.256 big bore, 10:2:1 compression, mild cam). Carbs were also rebuilt to accommodate new build. Unfortunately, engine runs like crap with incessant backfire out of exhaust and carbs (during both acceleration and deceleration). Hard to even really tell yet how the increase in displacement feels due to the bucking and backfiring. However, I do know that power seems to peak at mid 4K range. Planned to have dyno'd but until this is resolved no point. Their estimated build time of 2 months took 14 months and still not drivable so I'm a bit frustrated. Indy acknowledges that he doesn't know what the issue is. Said he suspects its carbs but not certain. Wants me to invest in a new set. To be clear, the carbs have worked perfectly for the last 10 years up to the day i dropped off to their shop. Indy acknowledges no issue with carbs when he received. Frankly, I've lost all confidence and contemplating having another shop look at this issue and resolve. In all fairness, this is not a hack shop...very reputable. I don't want to bash/mention names. Requesting recommendation of an indy, ideally in Maryland, that is capable of assessing and hopefully fixing the issue.
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
This sounds like a timing issue. What type of distributor are you running? have you verified that all spark plug wires are connected, and in the correct firing order on the dizzy?
BK911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None ![]() |
This sounds like a timing issue. What type of distributor are you running? have you verified that all spark plug wires are connected, and in the correct firing order on the dizzy? Many fuel related issues are timing issues. Set dwell/timing before messing with carbs. Good luck!! |
william1764 |
This sounds like a timing issue. What type of distributor are you running? have you verified that all spark plug wires are connected, and in the correct firing order on the dizzy? Many fuel related issues are timing issues. Set dwell/timing before messing with carbs. Good luck!! Will look into. TY |
Lo-Fi Version | Time is now: 17th June 2024 - 03:33 AM |
