Engine rebuild woes |
william1764 |
Mar 14 2022, 11:25 AM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
Just had completed a full engine rebuild of my stock 2.0L (with Webers) to a 2.3L by a small Porsche indy in Maryland (2.256 big bore, 10:2:1 compression, mild cam). Carbs were also rebuilt to accommodate new build. Unfortunately, engine runs like crap with incessant backfire out of exhaust and carbs (during both acceleration and deceleration). Hard to even really tell yet how the increase in displacement feels due to the bucking and backfiring. However, I do know that power seems to peak at mid 4K range. Planned to have dyno'd but until this is resolved no point. Their estimated build time of 2 months took 14 months and still not drivable so I'm a bit frustrated. Indy acknowledges that he doesn't know what the issue is. Said he suspects its carbs but not certain. Wants me to invest in a new set. To be clear, the carbs have worked perfectly for the last 10 years up to the day i dropped off to their shop. Indy acknowledges no issue with carbs when he received. Frankly, I've lost all confidence and contemplating having another shop look at this issue and resolve. In all fairness, this is not a hack shop...very reputable. I don't want to bash/mention names. Requesting recommendation of an indy, ideally in Maryland, that is capable of assessing and hopefully fixing the issue.
Tdskip |
Mar 14 2022, 01:32 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Simple things first, understand the frustration and concern but the suggestion to make ignition and fueling are correct.
Having an separate independent shop - or friend - check compression or even better leak down test if the above doesn't sort it out. Hang in there. |
Lo-Fi Version | Time is now: 17th June 2024 - 03:52 AM |
