> Engine rebuild woes
william1764
post Mar 14 2022, 11:25 AM
Just had completed a full engine rebuild of my stock 2.0L (with Webers) to a 2.3L by a small Porsche indy in Maryland (2.256 big bore, 10:2:1 compression, mild cam). Carbs were also rebuilt to accommodate new build. Unfortunately, engine runs like crap with incessant backfire out of exhaust and carbs (during both acceleration and deceleration). Hard to even really tell yet how the increase in displacement feels due to the bucking and backfiring. However, I do know that power seems to peak at mid 4K range. Planned to have dyno'd but until this is resolved no point. Their estimated build time of 2 months took 14 months and still not drivable so I'm a bit frustrated. Indy acknowledges that he doesn't know what the issue is. Said he suspects its carbs but not certain. Wants me to invest in a new set. To be clear, the carbs have worked perfectly for the last 10 years up to the day i dropped off to their shop. Indy acknowledges no issue with carbs when he received. Frankly, I've lost all confidence and contemplating having another shop look at this issue and resolve. In all fairness, this is not a hack shop...very reputable. I don't want to bash/mention names. Requesting recommendation of an indy, ideally in Maryland, that is capable of assessing and hopefully fixing the issue.
falcor75
post Mar 15 2022, 03:57 AM
I just got hung up on that it idles fine but doesnt work when driving. I agree with many others. Get yourself a notepad and start checking everything and make carefull notes of what you have checked and what you have measured. No sense in spending money on guesses.
Compression, are all cylinders equal within reason
Leakdown, any oddities?
Fuel pressure, within spec?
Timing,
Distributor and ignition leads installed and hooked up correctly
How does the spark plugs look, are they wet or sooty etc, make notes
Air leaks, both topside and bottom (exhaust side)
Carbs and linkage, sync between banks, measure drawn air with a synchrometer
Carb jets etc
There is no magic ticket, its just systematic fault elimination and keeping notes.
william1764   Engine rebuild woes   Mar 14 2022, 11:25 AM
iankarr   This sounds like a timing issue. What type of dist...   Mar 14 2022, 11:37 AM
william1764   This sounds like a timing issue. What type of dis...   Mar 14 2022, 12:19 PM
BK911   This sounds like a timing issue. What type of dis...   Mar 14 2022, 12:53 PM
william1764   This sounds like a timing issue. What type of di...   Mar 14 2022, 01:21 PM
nditiz1   Care to share who the Indy is? I'm not an exp...   Mar 14 2022, 11:42 AM
william1764   Care to share who the Indy is? I'm not an ex...   Mar 14 2022, 12:23 PM
930cabman   Just had completed a full engine rebuild of my st...   Mar 14 2022, 12:42 PM
emerygt350   Just looking at the picture tells me the plug wire...   Mar 14 2022, 01:02 PM
william1764   Just looking at the picture tells me the plug wir...   Mar 14 2022, 01:23 PM
Tdskip   Simple things first, understand the frustration an...   Mar 14 2022, 01:32 PM
ndfrigi   yes looks like wrong spark plug wires installation...   Mar 14 2022, 01:34 PM
nditiz1   The distro looks to be a Mallory. I believe when ...   Mar 14 2022, 02:03 PM
william1764   The distro looks to be a Mallory. I believe when...   Mar 14 2022, 02:17 PM
william1764   Great advice all, thank you. I failed to mention ...   Mar 14 2022, 02:03 PM
Shivers   Great advice all, thank you. I failed to mention...   Mar 14 2022, 02:20 PM
wonkipop   [quote name='william1764' post='2988099' date='Ma...   Mar 14 2022, 05:01 PM
emerygt350   Only thing I can think of is cold engine ran, warm...   Mar 14 2022, 02:20 PM
nditiz1   Adding more info OP supplied in a PM- "The e...   Mar 14 2022, 05:47 PM
Badinfluence1   I had a funky distributor that I had similar probl...   Mar 14 2022, 06:15 PM
emerygt350   Yeah, first, double check the plug wire order, the...   Mar 14 2022, 06:32 PM
emerygt350   Yeah, first, double check the plug wire order, th...   Mar 14 2022, 06:33 PM
targa72e   you need to start at square one. With a compressio...   Mar 14 2022, 10:09 PM
falcor75   Is 32 venturis big enough for a 2,3 with high comp...   Mar 15 2022, 01:10 AM
Shivers   I put CB performance kits in my 40's. The vent...   Mar 15 2022, 03:06 AM
falcor75   I just got hung up on that it idles fine but doesn...   Mar 15 2022, 03:57 AM
Superhawk996   There is no magic ticket, its just systematic f...   Mar 15 2022, 06:38 AM
rfinegan   Pull a Jet stack and Idle jet and let us know what...   Mar 15 2022, 04:31 AM
rhodyguy   That's a Mallory Unilite for the dist. Usually...   Mar 15 2022, 07:30 AM
VaccaRabite   Your mechanic set the idle and maybe never drove t...   Mar 15 2022, 08:00 AM
william1764   Your mechanic set the idle and maybe never drove ...   Mar 15 2022, 01:46 PM
VaccaRabite   Hi Zach - What shop would you recommend? Maryla...   Mar 16 2022, 10:14 AM
nditiz1   Bring it on up to Mount Airy, we can take a look.   Mar 15 2022, 01:51 PM
VaccaRabite   Bring it on up to Mount Airy, we can take a look...   Mar 16 2022, 10:15 AM
william1764   Bring it on up to Mount Airy, we can take a loo...   Mar 16 2022, 02:43 PM
william1764   Bring it on up to Mount Airy, we can take a look...   Mar 16 2022, 02:49 PM
cgnj   Hi, If that is a unilite, the tin needs to be mas...   Mar 29 2022, 08:55 PM
rhodyguy   Or, install the plug wires starting on true #1 in ...   Mar 30 2022, 02:04 PM
- Lo-Fi Version Time is now: 17th June 2024 - 04:00 AM
