> 914 V8 Resurrection, Fuel Tank / Carb questions
MM1
post Mar 18 2022, 01:30 PM
914 obsession continues
Dear 914 Guru’s,
I recently picked up the (carbureted) red 1974 914-V8 project that was sold here on the world. I’m hoping the brain trust can guide me in getting started . . .
The tank and sending unit are all crusty - I’d like to avoid the tank cleaning/re-lining nightmares I’ve gone through before and just get a new tank. I can pick up a Dansk 1973 and earlier tank along with a URO fuel level sending unit for around $360(shipped). Will these install (without mods) and work with the straps/wiring/gauges of a 1974? (There’s no expansion tank/charcoal canister in the car.)Any opinions on these 2 parts/brands (vs Dansk sending unit)?
Is it worth it to spend quite a bit more ($525+ at Pelican) for the Dansk 1974-up tank and a Dansk fuel level sending unit (website said it only works with 100L tank . . .is there a capacity difference between gen 1 and gen 2 tanks?)?
Carburetor: it’s a Weber 4-barrel- I haven’t found any numbers yet and I have no idea what CFM it is. I didn’t even know Weber made a four barrel and it’s difficult to find much info on the Internet . . . I thought I read it’s a Carter AFB copy - I cannot confirm that though. They are still sold for marine applications.
Any thoughts? The car sat for many years and the PO who had it about six weeks said he cleaned the jets out but didn’t rebuild the carb. I got it to start a few times and after it warmed up it seemed to fuel correctly but ran out of fuel or got clogged up after a few minutes of running ( at which point I opened up the tank to see that it was quite crusty). Should I rebuild this carb ? Or would it be smarter to buy a new carb ?( it’s a Chevrolet 283c.i. V8 with an Edelbrock Performer intake and rams horn exhaust manifolds and an electric fuel pump in the engine bay. I have no idea if it is a stock motor or not- the only thing I could find in the records is that one shop thought it was from 1968.)
If some of you suggest a new carb instead of rebuilding the Weber what CFM and brand would you go with?
Your advice, as always, deeply appreciated and priceless. . . (IMG:style_emoticons/default/pray.gif)
Robarabian
post Mar 18 2022, 10:01 PM
914 A Roo
The Carter copy is a 500 CFM model... remember, you are not running a 350 but a 283.. a 350 can handle a 600-650 CFM.. anything more than 550 will overcarburate that thing.
I like the Holley setup, the 2 barrel version is for an engine your size.
No input on the gas tanks. I think we clean the weber.. I have a Carter for you if you want it. It may be large for the car.
Rob
MM1
post Mar 19 2022, 12:00 PM
QUOTE(Robarabian @ Mar 18 2022, 11:01 PM) *
Rob
Thanks, Rob -sounds good!
MM1   914 V8 Resurrection   Mar 18 2022, 01:30 PM
Root_Werks   Sounds like the carb might be okay and just cloggi...   Mar 18 2022, 02:03 PM
FL000   I have a 73 and put a Dansk in last year. Not sure...   Mar 18 2022, 03:21 PM
Front yard mechanic   I would buy a new carb if you have the $ a ne...   Mar 18 2022, 04:45 PM
tygaboy   I have a Dansk tank in my '75 V8 car. They fit...   Mar 18 2022, 04:52 PM
slowrodent   Just an opinion... but if it was mine, I'd loo...   Mar 18 2022, 04:59 PM
tygaboy   :agree: I almost added this very comment but didn...   Mar 18 2022, 05:36 PM
MM1   Thank you all for your advice and support!   Mar 18 2022, 07:42 PM
MM1   Sounds like there's not much to say about the ...   Mar 18 2022, 07:44 PM
Shivers   Sounds like there's not much to say about the...   Mar 19 2022, 01:40 PM
Robarabian   The Carter copy is a 500 CFM model... remember, yo...   Mar 18 2022, 10:01 PM
MM1   The Carter copy is a 500 CFM model... remember, y...   Mar 19 2022, 12:00 PM
john ee quest   Dear 914 Guru’s, I recently picked up the (ca...   Mar 19 2022, 01:13 PM
john ee quest   I had the same question, I thought all years were ...   Mar 19 2022, 01:21 PM
MM1   Thank you for checking into that @ John ee quest...   Mar 20 2022, 11:45 AM
Chris914n6   So the tank crust is likely not as bad as you thin...   Mar 20 2022, 03:53 PM
nivekdodge   So the tank crust is likely not as bad as you thi...   Apr 21 2022, 06:36 PM
Chris914n6   Chris, Have you done a Fitech install on yours...   Apr 21 2022, 09:12 PM
MM1   Got the tank out yesterday tank. . .I'll spare...   Mar 21 2022, 11:23 AM
MM1   Thank you @Chris914n6 for the E10/powder through...   Mar 21 2022, 11:29 AM
- Lo-Fi Version Time is now: 16th June 2024 - 07:40 PM
