| yeahmag |
Mar 21 2022, 11:22 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Got a strange one... Alternator light started flickering on my way to this weekends autocross. This was on the highway at steady rpm of around 4K. I hadn't seen it flicker like this before: sometimes on dim, sometimes on for a few seconds at a time, sometimes flickering.
I figured I'd just carry on and hope I could make it through the event. As I pulled off the freeway on to surface streets the light went off and didn't come back on for the duration of the event. Packed up and headed home and only had a brief flicker or two while on the highway. I've never seen it come on while on surface streets or at idle. I figured I'd check the alternator for AC voltage (failed diode) and maybe change the belt (which I personally run on the loose side and is probably aging out). Anything else I should look for? Almost feels like a marginal VR, but I've never had one fail in this way. Thanks! -Aaron |
| yeahmag |
Mar 22 2022, 07:40 PM
Totally unknown on the age and mileage. Always been rock solid. I would think (and I could be wrong here), poor brush spring tension would go away at higher RPM.
yeahmag Intermittent Alternator Light Mar 21 2022, 11:22 AM
Spoke ...the belt (which I personally run on the loose s... Mar 21 2022, 11:41 AM
emerygt350
...the belt (which I personally run on the loose ... Mar 21 2022, 12:18 PM
yeahmag I'm leaning heavily towards the VR at this poi... Mar 21 2022, 12:20 PM
emerygt350 I recently installed a hella solid state, very imp... Mar 22 2022, 05:51 AM
yeahmag
I recently installed a hella solid state, very im... Mar 22 2022, 10:41 AM
vitamin914
[quote name='emerygt350' post='2989984' date='Mar... Mar 23 2022, 12:48 PM
emerygt350
[quote name='emerygt350' post='2989984' date='Ma... Mar 23 2022, 01:07 PM
914Mels If it's an old alternator with lots of miles y... Mar 22 2022, 10:50 AM
914Mels The shorter the brushes get the less the spring te... Mar 22 2022, 08:19 PM
Spoke You could run some simple tests with engine runnin... Mar 23 2022, 11:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:13 AM |
