> Intermittent Alternator Light
yeahmag
post Mar 21 2022, 11:22 AM
Got a strange one... Alternator light started flickering on my way to this weekends autocross. This was on the highway at steady rpm of around 4K. I hadn't seen it flicker like this before: sometimes on dim, sometimes on for a few seconds at a time, sometimes flickering.
I figured I'd just carry on and hope I could make it through the event. As I pulled off the freeway on to surface streets the light went off and didn't come back on for the duration of the event. Packed up and headed home and only had a brief flicker or two while on the highway. I've never seen it come on while on surface streets or at idle.
I figured I'd check the alternator for AC voltage (failed diode) and maybe change the belt (which I personally run on the loose side and is probably aging out). Anything else I should look for? Almost feels like a marginal VR, but I've never had one fail in this way.
Thanks!
-Aaron
emerygt350
post Mar 22 2022, 05:51 AM
I recently installed a hella solid state, very impressed with it. 13.8 all day.
yeahmag
post Mar 22 2022, 10:41 AM
QUOTE(emerygt350 @ Mar 22 2022, 04:51 AM) *
Interesting. Mind sharing where you got it from?
vitamin914
post Mar 23 2022, 12:48 PM
QUOTE(yeahmag @ Mar 22 2022, 11:41 AM) *
This is where I got mine a few weeks ago...
https://www.pelicanparts.com/More_Info/0021...2-154-74-06-M44
- Lo-Fi Version Time is now: 2nd April 2026 - 11:14 AM
